[GRASS-user] d.mon error (X11 problem?)
Lee Eddington
lee.w.eddington at gmail.com
Mon Nov 11 20:41:52 PST 2013
Well it's not critical, as I'm able to display the data in the WxGUI Map
Display. Now I'm stumped with georeferencing my data (next post).
Thanks
On Mon, Nov 11, 2013 at 8:30 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> Yeah, XQuartz is not a drop-in replacement to Apple's old X11, it's
> installed in in a completely different location. It may still be
> compatible and work if GRASS can be relinked. I'll have to experiment, but
> that may be a while since I haven't upgraded to Mavericks yet.
> On Nov 11, 2013, at 8:25 PM, William Kyngesburye wrote:
> > It's possible that the XQuartz libraries are not compatible with the old
> X11, which the current GRASS binaries are built with. GRASS would need to
> be recompiled for XQuartz.
> > On Nov 11, 2013, at 8:12 PM, Lee Eddington wrote:
> >> Marvin,
> >> I've downloaded and installed XQuartz but I'm still getting the same
> error. I've tried starting X11 before GRASS and starting GRASS from the
> xterm command line, but no luck.
> >> Thanks,
> >> Lee
> >> On Mon, Nov 11, 2013 at 4:34 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> >> Starting with 10.8 (I think) Apple stopped providing an X11 package.
> You need to download and install X11 (XQuartz) on your own now.
> >> xquartz.macosforge.org
> >> (doesn't seem to be responding at the moment)
> >> On Nov 11, 2013, at 1:51 PM, Lee Eddington wrote:
> >>> I’ve recently started using GRASS again after a few years and I don’t
> remember a lot. I previously worked with it for just a few months and was
> able to get some work accomplished, but I’m still a novice. I’m working on
> a Mac with Mac OS X 10.9 and when I try to open a display monitor from the
> command line I get the following:
> >>> GRASS 6.4.3 (bali_d03):~ > d.mon x0
> >>> ERROR: no such monitor 'x0'
> >>> ERROR: No such monitor as <x0>
> >>> Problem selecting x0. Will try once more
> >>> I went back to my old system that I used GRASS on before (GRASS
> 6.4.0RCS running Mac OS X 10.6.8) and d.mon x0 worked fine.
> >>> Any help would be appreciated.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131111/c68d24d6/attachment.html>
