[GRASS-user] ordering points along a line
    Carlos Grohmann
    carlos.grohmann at gmail.com
    Mon Nov 18 10:39:28 PST 2013
Hi there
I've been looking into this, but not sure about the best way to do it:
I have a set of points that lie over a line (the line is a river course and
points are intersections with contour lines). I want to order the points
'downstream', so I can make a long profile of the river (just sampling
elevations from a DEM at line nodes gives too much noise, some papers
suggest contours intersections work better).
Question is: how? After some searching I found the Network Analysis of
QGIS, but still not sure if that's the best approach. The river is very
meandering, so nearest neighbour won't work because the nearest node might
not be the next one downstream
I'm open to suggestions
thanks
Carlos
Prof. Carlos Henrique Grohmann
Institute of Geosciences - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131118/68ce71e8/attachment.html>
