[GRASS-user] how to import e00 data
Simone Gabbriellini
simone.gabbriellini at gmail.com
Wed Nov 20 08:19:26 PST 2013
mmm, I really give up... it's impossibly complicated to have a result.
Maybe I should try to find another GIS software, less powerful but simpler.
Thanks anyway for your help.
2013/11/20 Rich Shepard <rshepard at appl-ecosys.com>:
> On Wed, 20 Nov 2013, Simone Gabbriellini wrote:
>> Did it, this is what I have:
>> PRJ 2
>> Projection GEOGRAPHIC
>> Zunits NO
>> Units DD
>> Spheroid CLARKE1866
> Simone,
> It's unprojected, lat/long, in decimal degrees.
>> Looks like the ESPG code is 4302, then I proceed to import all the files,
>> then add vector maps to layer manager... but I cannot see anything
>> there... just a white map display...
> From within the layer manager window select that map by right-clicking on
> it. One of the menu options is to set the view to that map. Try this.
> I work infrequently with the ESPG codes; usually specify the location by
> details. In your case I'd set a location called India-LL (for lat/long);
> perhaps that's what the ESPG code represents.
> Rich
> Richard B. Shepard, Ph.D. | Have knowledge, will travel.
> Applied Ecosystem Services, Inc. |
> <http://www.appl-ecosys.com> Voice: 503-667-4517 Fax: 503-667-8863
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Simone Gabbriellini, PhD
Post-doctoral Researcher
ANR founded research project "DIFFCERAM"
GEMASS, CNRS & Paris-Sorbonne.
mobile: +39 340 39 75 626
email: simone.gabbriellini at gmail.com
