[GRASS-user] how to import e00 data
Rich Shepard
rshepard at appl-ecosys.com
Wed Nov 20 08:09:43 PST 2013
On Wed, 20 Nov 2013, Simone Gabbriellini wrote:
> Did it, this is what I have:
> PRJ 2
> Projection GEOGRAPHIC
> Zunits NO
> Units DD
> Spheroid CLARKE1866
Simone,
It's unprojected, lat/long, in decimal degrees.
> Looks like the ESPG code is 4302, then I proceed to import all the files,
> then add vector maps to layer manager... but I cannot see anything
> there... just a white map display...
From within the layer manager window select that map by right-clicking on
it. One of the menu options is to set the view to that map. Try this.
I work infrequently with the ESPG codes; usually specify the location by
details. In your case I'd set a location called India-LL (for lat/long);
perhaps that's what the ESPG code represents.
Rich
Richard B. Shepard, Ph.D. | Have knowledge, will travel.
Applied Ecosystem Services, Inc. |
<http://www.appl-ecosys.com> Voice: 503-667-4517 Fax: 503-667-8863
