[GRASS-user] i.landsat.toar comments have only 0 value
Pekka Hurskainen pekka.hurskainen at gmail.com
Mon Nov 25 02:05:03 PST 2013
Unless I have missed something obvious, the problem described by Beatrice
with i.landsat.toar still exists?
I've tried both WinGrass 7.0.svn build 2013-11-24 and WinGrass 6.4.4svn,
revision 58275 (2013-11-24).
I've tested with a L8 and L5 scene (both with the new metadata file), using
'uncorrected' atmospheric correction method. I just chose the sensor type
and left everything else default.
Both command output (verbose) and r.info print zeros for Earth-sun
distance, Sun elevation, DN range, Calibration constants, DN to Radiance,
ESUN and Radiance to Reflectance values.
The output files give sensible reflectance values, but can I trust them
(i.e. the metadata file was read correctly and the right parameters were
used)? I haven't compared with Linux version.
BR
Pekka
On Thu, Oct 24, 2013 at 12:33 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 23, 2013 at 11:23 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> > Hi Beatrice,
> > I just checked in new updated for i.landsat.toar to fix Landsat-8
> > metadata file support (author: E. Jorge Tizado) into SVN.
> > By tomorrow morning European time zone the updated winGRASS 6 package
> > should be ready.
> > TODO: sync the version in G7, too.
> Done, too.
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Pekka Hurskainen
+358-44-3390018
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131125/34742438/attachment.html>
