[GRASS-user] Grass SQLite driver & math funtions
Enrico Gallo
enrico.gallo at gmail.com
Tue Oct 1 11:54:37 PDT 2013
2013/9/26 Pietro <peter.zamb at gmail.com>
> On Thu, Sep 26, 2013 at 2:18 PM, Enrico Gallo <enrico.gallo at gmail.com>
> wrote:
> > So there is not a way to use this kind of funtions with vector attributes
> > without compile extra library and load it in SQLIte?
> > Any python workaround?
> this example works only in grass7, otherwise you have to write your
> python code to work directly with the sqlite table.
> # work around
> import math
> for geo in foo:
> geo.attrs['level'] = geo.attrs['power'] -
> math.log10(geo.attrs['distance'])
> Note that this is far to be efficient...
As I have to manage table with 1E5 - 1E6 rows, I will try some python code
using pysqlite or APSW
thank you in any case for suggestions and workaround
best regards,
Enrico
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131001/e8803e3b/attachment.html>
