[GRASS-user] segmented operations in r.drain and r.los
ALT SHN
i.geografica at alt-shn.org
Tue Oct 1 16:42:14 PDT 2013
I suppose one can have what I call "segmented operations" with certain
GRASS modules, for example:
- In *r.drain* I want make sure that certain points of the raster are
mandatory stops; I know I can run r.cost multiple times (a to b; b to c;
and so on). My question is how can I do it in a single command? Using the
GRASS shell, I suppose - can someone give me a example?
- the same question applies to r.los - can I calculate several visible
areas with a single command?
Thanks for any hints!
Regards,
André
SOCIEDADE DE HISTÓRIA NATURAL - Departamento de Informação Geográfica
Apartado 25 2564-909 Torres Vedras Portugal
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
do Ameal 2565-641 Ramalhal
http://alt-shn.blogspot.com
www.alt-shn.org
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131002/e1ebe70c/attachment.html>
