[GRASS-user] segmented operations in r.drain and r.los
Ivan Marchesini
ivan.marchesini at gmail.com
Tue Oct 1 22:03:47 PDT 2013
Hi
> - the same question applies to r.los - can I calculate several visible
> areas with a single command?
r.los allows to define the area that is visible from one point.
if you need to analyze more than one point you have to redo the analysis
(may be using a simple "for" cicle in bash)
Regards
Ivan
> SOCIEDADE DE HISTÓRIA NATURAL - Departamento de Informação Geográfica
> Apartado 25 2564-909 Torres Vedras Portugal
> Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres
> Vedras
> Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do
> Alto do Ameal 2565-641 Ramalhal
> http://alt-shn.blogspot.com
> www.alt-shn.org
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
