[GRASS-user] v.in.ascii : ERROR: write sidx
Nikos Alexandris
nik at nikosalexandris.net
Thu Oct 3 17:44:14 PDT 2013
Yann wrote:
> > The command was :
> > v.in.ascii -z input=${FILE} output=${NAME_OUT} separator="${FS}" z=3
> > --overwrite
Hamish wrote:
> Hi,
> just to note -- the {curly} brackets do nothing to
> protect from spaces in filenames in this situation,
> "double" quotes should be used for that.
> the curly brackets protect the variable name, not its
> contents, so are mostly useful for when a letter,
> number, or "_" follows the variable name.
> I actually think it is dangerous to use the curly
> brackets because it tricks people into thinking they
> are protected when they are not.
Maybe "${FILE}" then? I remember this as being Glynn's recommendation, some
time ago...
Best, Nikos
