[GRASS-user] Classes names in rasters
Nikos Alexandris nik at nikosalexandris.net
Wed Oct 9 10:03:37 PDT 2013
Luisa Peña wrote:
> > I have produced a raster map with landcover classes and I wanted to know
> > if it is possible to have raster names instead of numeric values when I
> > use the point-and-click options or even when I export as Geotiff?
Moritz Lennert wrote:
> I'm not sure I understand exactly what you are trying to do (what are
> point-and-click options ?),
I think Luisa refers to the "Query raster/vector maps" button (5th from left
to right in the (Map) Display.
I think that currently the behaviour in the wxGUI is "buggy".  For example, I
have assigned "1:2:Water" and when I click on a "1" cell, the label does not
appear in the "Query Results" window. However, it works for "2:Water".  I
would expect that "1" also appears in the results as "label 1:Water" (besides
of the "color: ... and value: 1"  which work fine).
Nikos
