[GRASS-user] GRASS7 d.mon
Daniel McInerney daniel.o.mcinerney at gmail.com
Mon Oct 14 08:43:56 PDT 2013
ok. the only difference this time, is that i passed --with-cairo to
./configure. Having said that the previous install had cairo support. I
also updated the region settings before running d.rast.
Daniel
On Mon, Oct 14, 2013 at 5:38 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi Daniel,
> 2013/10/14 Daniel McInerney <daniel.o.mcinerney at gmail.com>:
> > Many thanks Martin, that revision has solved the problem.
> in this revision I just changed the error message to report more
> detailed info about failure. So it cannot be the reason why it's
> working now for you. Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131014/d91e6330/attachment-0001.html>
