[GRASS-user] Start GRASS 7 on OS X directly into text mode?
Rainer M Krug
Rainer at krugs.de
Tue Oct 15 02:08:03 PDT 2013
Hi
Found the solution:
using
/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh --text
works.
Are there any downsides to this approach I miss?
Thanks,
Rainer
Rainer M Krug <Rainer at krugs.de> writes:
> Hi
> under linux, I would say:
> | grass70 -text THEMAPSET
> but I can't figure out, how I can do this on OS X.
> | open -a GRASS-7.0.app --args --text
> does not work (starts normally) and does not seem to take any
> arguments - is this correct?
> Additionally, I would like to start this process in an already open
> terminal, and not open a new one.
> Any suggestions?
<#secure method=pgpmime mode=sign>
Rainer M. Krug
email: RMKrug<at>gmail<dot>com
