[GRASS-user] Start GRASS 7 on OS X directly into text mode?
Vaclav Petras
wenzeslaus at gmail.com
Sat Oct 19 17:30:33 PDT 2013
On Tue, Oct 15, 2013 at 5:08 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> Hi
> Found the solution:
> using
> /Applications/GRASS-7.0.app/Contents/MacOS/grass.sh --text
> works.
> Are there any downsides to this approach I miss?
> I'm interested in the answer, too. I got an impression that in Mac OS app
package there is always some sh or something which takes care of
everything, so probably the sh is fine unless it will be changed to
something else by packager which is not probable. But this is more guessing
than anything else.
Thanks,
> Rainer
> Rainer M Krug <Rainer at krugs.de> writes:
> > Hi
> > under linux, I would say:
> > | grass70 -text THEMAPSET
> > but I can't figure out, how I can do this on OS X.
> > | open -a GRASS-7.0.app --args --text
> > does not work (starts normally) and does not seem to take any
> > arguments - is this correct?
> > Additionally, I would like to start this process in an already open
> > terminal, and not open a new one.
> > Any suggestions?
> <#secure method=pgpmime mode=sign>
> Rainer M. Krug
> email: RMKrug<at>gmail<dot>com
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131019/d794333e/attachment.html>
