[GRASS-user] libintl8.dll not found
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Oct 17 05:58:54 PDT 2013
Hi
I can confirm the problem with the libintl8.dll, strange enough across different versions of GRASS 6.4.2, 6.4.3, 6.4.4 both installed via OSGeo4W, GRASS standalone and QGIS standalone installer (QGIS from Jan 2013).
Furthermore the problem occurs also on different windows versions: XP, Vista, and 7. It seems to affect "only" the GUI because also on non-working installations GRASS can be accessed via QGIS...
Sounds like Python-related problems?
Cheers
Stefan
-----Original Message-----
From: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of FNK
Sent: 16. oktober 2013 13:17
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] libintl8.dll not found
Hello,
Installing MinGW hasn't solved it. I've installed everything from OSGeo4W, included GRASS 6.4.3 and now the error is that it doesn't find libgrass_gis.6.4.3.dll.
My problem is not exactly the same from that ticket because the .dll file exists in the installation directory but it doesn't find it.
I need to use GRASS 6 becase GRASS 7 is not stable.
Do you have another idea??? Thanks for your help.
View this message in context: http://osgeo-org.1560.x6.nabble.com/libintl3-dll-not-found-tp5083833p5083886.html
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
