[GRASS-user] How to delete small closed lines, problems with v.edit and v.generalize
BLANDENIER Lucien
lucien.blandenier at unine.ch
Mon Oct 21 07:48:21 PDT 2013
Hello,
I'm trying to simplify a contour map I've done with r.contour. I want to remove small area but when I use the command v.edit map=<map> tool=delete thresh=1000 query=length, only "non-closed map" are considered and the "closed line" (there are really lines, not polygons) remain.
I've the same problem with the command v.generalize.
Does someone knows how to consider all the lines ?
Attached is my shp.
Regards
Lucien
Type: application/octet-stream
Desc: Head_Interp_Rast_contour.dbf
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment-0002.obj>
Desc: Head_Interp_Rast_contour.prj
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment-0003.obj>
Type: application/x-qgis
Desc: Head_Interp_Rast_contour.shp
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment-0001.shp>
Desc: Head_Interp_Rast_contour.shx
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment-0001.shx>
