[GRASS-user] grass-user Digest, Vol 90, Issue 35
Rabotin Michael rabotin at supagro.inra.fr
Mon Oct 21 08:47:40 PDT 2013
Le 21/10/2013 16:48, grass-user-request at lists.osgeo.org a écrit :
> Send grass-user mailing list submissions to
> 	grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>     1. How to delete small closed lines, problems with v.edit and
>        v.generalize (BLANDENIER Lucien)
> Message: 1
> Date: Mon, 21 Oct 2013 14:48:21 +0000
> From: BLANDENIER Lucien <lucien.blandenier at unine.ch>
> To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Subject: [GRASS-user] How to delete small closed lines, problems with
> 	v.edit and v.generalize
> Message-ID:
> 	<84F1DDBD03D55944AA4E63A2FE5EADE5530A7CFE at MAIL-MBX-05.UNINE.CH>
> Content-Type: text/plain; charset="iso-8859-1"
> Hello,
> I'm trying to simplify a contour map I've done with r.contour. I want to remove small area but when I use the command v.edit map=<map> tool=delete thresh=1000 query=length, only "non-closed map" are considered and the "closed line" (there are really lines, not polygons) remain.
Hello,
did you try to transform your line vector into a polygon vector and use
after a v.clean command with tool=rmarea ? So only the small area will
be removed and after you can again transform your polygon vector into a
lin vector
Mick
> I've the same problem with the command v.generalize.
> Does someone knows how to consider all the lines ?
> Attached is my shp.
> Regards
> Lucien
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: application/octet-stream
> Desc: Head_Interp_Rast_contour.dbf
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.obj>
> Desc: Head_Interp_Rast_contour.prj
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment-0001.obj>
> Type: application/x-qgis
> Desc: Head_Interp_Rast_contour.shp
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.shp>
> Desc: Head_Interp_Rast_contour.shx
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.shx>
> End of grass-user Digest, Vol 90, Issue 35
Signature electronique
INRA <http://www.inra.fr>
*Michael Rabotin*
*Ingénieur d'Etude SIG / GIS Engineer*
michael.rabotin at supagro.inra.fr <mailto:#>
*UMR LISAH - Centre de Montpellier*
Tèl. : +33 (0)4 99 61 23 85
Mobile : +33 (0)6 76 45 46 83
Fax : +33 (0)4 67 63 26 14
Bat 24 - 2 place Pierre Viala
34060 Montpellier cedex 2
France
www.inra.fr <http://www.inra.fr> 	www.openfluid-project.org
<http://www.openfluid-project.org>
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/4f6f1757/attachment.html>
Une pi?ce jointe autre que texte a ?t? nettoy?e...
Nom: logo-INRA2012.gif
Type: image/gif
Taille: 2560 octets
Desc: http://www.inra.fr/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/4f6f1757/attachment.gif>
