[GRASS-user] GRASS and libgeos 3.1.1/3.3.3
Hamish hamish_b at yahoo.com
Tue Sep 3 14:33:41 PDT 2013
> [g.region failing on ubuntu 13.04 causing main startup to fail]
oops, that was g.proj failing.
> I see g.region only depends on PROJ.4 though, not GDAL..
> (what version of the libproj is installed?)
g.proj depends on GDAL libs which depends on GEOS.
what version of GDAL is installed? 1.9.0-3.1ubuntu1?
$ dpkg -l | grep libgdal
what does this say:
$ ldd /usr/lib/grass64/bin/g.proj | grep geos
Hamish
