[GRASS-user] DEM creation from aerial photography
    Benjamin Ducke
    benducke at fastmail.fm
    Tue Sep 10 02:11:02 PDT 2013
One of the handiest solutions for extracting 3D data
using SfM is this:
http://homes.cs.washington.edu/~ccwu/vsfm/
It includes georeferencing and can handle the coordinate
ranges that occur in geographical data. It is free
to use for non-commercial applications but unfortunately
not open source.
Anyhow, SfM works best when there is a large series
of images with a lot of overlap and small angular
displacement between consecutive images. Traditional aerial
imagery will not always give good results. There can also
be trouble with the simple camera model that some SfM
tools (including VSFM) use.
An open source solution that is optimised for remote
surveying applications is currently lacking, AFAIK.
Best,
Ben
On 09/10/2013 04:45 AM, Tim Bowden wrote:
> On Mon, 2013-09-09 at 15:08 +0200, Markus Neteler wrote:
>> On Mon, Sep 9, 2013 at 10:59 AM, Tim Bowden <tim.bowden at mapforge.com.au> wrote:
>>> Hi,
>>> If all I've got is raw (ie, unrectified) aerial photography & sufficient
>>> ground control points, what is the process for creating a DEM (assuming
>>> it's possible with GRASS)?  I've not been able to find any documentation
>>> apart from orthorectification using an existing DEM.
>> You can find something in the Wiki
>> http://grasswiki.osgeo.org/wiki/Stereoscopic_analysis#GRASS_5
>> There is an old software "stereo" which seems to offer this, see links there.
>> It would be great to get this functionality into GRASS 7.
>> Markus
> Thanks Markus,
> For now this capability seems to be 'missing'.  Once again I'm
> left wishing I was a competent c/c++ programmer (wip...).
> In any event, I suspect this approach has been mostly (?) superseded by
> 'Structure from Motion' type modelling which I'm also playing with- was
> just hoping to be able to add 'traditional' photogrammetric  modelling
> to my toolkit and be able to do a comparison between the two).
> Regards,
> Tim Bowden
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dr. Benjamin Ducke, M.A.
{*} Geospatial Consultant
{*} GIS Developer
