[GRASS-user] Impossible to install GRASS - problem with libgdal1
BLANDENIER Lucien
lucien.blandenier at unine.ch
Wed Sep 11 05:34:54 PDT 2013
Following my previous message...
I found the package libgdal1 but for installing it I have to uninstall libgdal1h and also qgis... I did it and then tried to install qgis again but synaptic had to uninstal grass and libgdal1...
It now impossible to work with GRASS and Qgis simultanuously.
Any idea?
Thanks
________________________________________
De : grass-user-bounces at lists.osgeo.org [grass-user-bounces at lists.osgeo.org] de la part de BLANDENIER Lucien [lucien.blandenier at unine.ch]
Envoyé : mercredi 11 septembre 2013 14:09
À : grass-user at lists.osgeo.org
Objet : [GRASS-user] Impossible to install GRASS
Hello,
I recently tried to re-install GRASS because after my last update of GRASS and Qgis (about 2 weeks ago) the GRASS plugin in Qgis was no more available.
So, I first update GRASS and Qgis but there was a problem with the libgdal1. I've update all the packages with apt-get update (I'm on linux mint) and I received the following messaege :
$ W: Duplicate sources.list entry http://ppa.launchpad.net/ubuntugis/ubuntugis-testing/ubuntu/ precise/main amd64 Packages (/var/lib/apt/lists/ppa.launchpad.net_ubuntugis_ubuntugis-testing_ubuntu_dists_precise_main_binary-amd64_Packages)
$ W: Duplicate sources.list entry http://ppa.launchpad.net/ubuntugis/ubuntugis-testing/ubuntu/ precise/main i386 Packages (/var/lib/apt/lists/ppa.launchpad.net_ubuntugis_ubuntugis-testing_ubuntu_dists_precise_main_binary-i386_Packages)
$ W: Vous pouvez lancer « apt-get update » pour corriger ces problèmes.
Then, I tried to reinstall QGis and GRASS. Qqis is working fine now. But GRASS with the command $ sudo apt-get install grass
I become the following error message. It is in French but it says that some packages can not be installed and that there is a problem with the dependence libgdal1(>=1.8.0)
$ Lecture des listes de paquets... Fait
$ Construction de l'arbre des dépendances
$ Lecture des informations d'état... Fait
$ Certains paquets ne peuvent être installés. Ceci peut signifier que vous avez demandé l'impossible, ou bien, si vous utilisez la distribution unstable, que certains paquets n'ont pas encore été créés ou ne sont pas sortis d'Incoming.
$ L'information suivante devrait vous aider à résoudre la situation :
$ Les paquets suivants contiennent des dépendances non satisfaites :
$ grass : Dépend: libgdal1 (>= 1.8.0) mais ne sera pas installé
$ E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l'état ».
Does someone knows what is the problem?
Thanks
Lucien
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
