[GRASS-user] Impossible to install GRASS - problem with libgdal1
Hamish hamish_b at yahoo.com
Thu Sep 12 13:11:42 PDT 2013
Lucien wrote:
> For thoose you had the same problem.
> I solved it like this:
> - uninstall Qgis and GRASS
> - remove all the repository for the installation of qgis and GRASS
> - reload the repository $ sudo apt-add-repository
> ppa:ubuntugis/ubuntugis-unstable
> - reinstall qgis and GRASS
> it is working fine!
thanks for the all-clear report.
I suspect it might be some newer package that should have a "Conflicts"
setting with some older generation package, which only becomes an issue
if the tide rises unevenly..  ?  shrug
Hamish
