[GRASS-user] Fwd: Esri Software Update Notification: Update to Alert Issued on May 14, 2013
Michael Barton Michael.Barton at asu.edu
Fri Sep 13 10:28:16 PDT 2013
I'm glad that I use GRASS
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www:  http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
Begin forwarded message:
From: Esri <newsletter at esri.com<mailto:newsletter at esri.com>>
Subject: Esri Software Update Notification: Update to Alert Issued on May 14, 2013
Date: September 13, 2013 10:11:39 AM MST
To: Michael Barton <michael.barton at asu.edu<mailto:michael.barton at asu.edu>>
[Esri - Understanding our world.]
[blue bar]
Information on Microsoft Patch to Fix Data Corruption Issue
In May of this year, we informed you about Microsoft update KB 2775511 that could result in data corruption when using ArcGIS on a Windows 7 system and writing data to remote data storage on a Windows Vista, 7, 2008/2008 R2, or 2012 system.
This is a follow-up to inform you that Microsoft has now released a fix under KB 2732673 for this issue.
Esri has tested the fix and verified that it resolves the data corruption problem previously mentioned.
The following describes what you need to do to apply this fix:
  *   If you previously installed Microsoft KB 2775511, download and install the update found in Knowledge Base article 2732673<http://autobahn.esri.com/esri/etrack.aspx?DSN=b9ca57b2fbe8cb42458807853387983f6a0f6be5ccdab113&FORMID=987c099fe12995c46059458324632afc&AUDID=1d1b97763e915159f36016c0f46fe0e9&EMAILID=8f9ff131ddf0d93209849360ad83fcf9ed298cefd1667847&DECODE=1&INTID=2dad22db1ebd20fdccc60fd624169bb2&URL=http://support.microsoft.com/kb/2732673?WT.mc_id=EmailCampaign17055a> according to the IT policies of your organization.
  *   If you have not yet installed Microsoft KB 2775511 but plan to do so at a future date, install the update found at KB 2732673<http://autobahn.esri.com/esri/etrack.aspx?DSN=b9ca57b2fbe8cb42458807853387983f6a0f6be5ccdab113&FORMID=987c099fe12995c46059458324632afc&AUDID=1d1b97763e915159f36016c0f46fe0e9&EMAILID=8f9ff131ddf0d93209849360ad83fcf9ed298cefd1667847&DECODE=1&INTID=2dad22db1ebd20fdccc60fd624169bb2&URL=http://support.microsoft.com/kb/2732673?WT.mc_id=EmailCampaign17055a> now to avoid any issues that may impact file geodatabases and shapefiles stored on network drives.
See Esri Knowledge Base article 41119<http://autobahn.esri.com/esri/etrack.aspx?DSN=b9ca57b2fbe8cb42458807853387983f6a0f6be5ccdab113&FORMID=987c099fe12995c46059458324632afc&AUDID=1d1b97763e915159f36016c0f46fe0e9&EMAILID=8f9ff131ddf0d93209849360ad83fcf9ed298cefd1667847&DECODE=1&INTID=2dad22db1ebd20fdccc60fd624169bb2&URL=http://support.esri.com/en/knowledgebase/techarticles/detail/41119?WT.mc_id=EmailCampaign17055a> for further information and updates.
Esri.com<http://autobahn.esri.com/esri/etrack.aspx?DSN=b9ca57b2fbe8cb42458807853387983f6a0f6be5ccdab113&FORMID=987c099fe12995c46059458324632afc&AUDID=1d1b97763e915159f36016c0f46fe0e9&EMAILID=8f9ff131ddf0d93209849360ad83fcf9ed298cefd1667847&DECODE=1&INTID=2dad22db1ebd20fdccc60fd624169bb2&URL=http://www.esri.com?WT.mc_id=EmailCampaign17055> | Privacy<http://autobahn.esri.com/esri/etrack.aspx?DSN=b9ca57b2fbe8cb42458807853387983f6a0f6be5ccdab113&FORMID=987c099fe12995c46059458324632afc&AUDID=1d1b97763e915159f36016c0f46fe0e9&EMAILID=8f9ff131ddf0d93209849360ad83fcf9ed298cefd1667847&DECODE=1&INTID=2dad22db1ebd20fdccc60fd624169bb2&URL=http://www.esri.com/legal/privacy.html?WT.mc_id=EmailCampaign17055> | Contact Us<http://autobahn.esri.com/esri/etrack.aspx?DSN=b9ca57b2fbe8cb42458807853387983f6a0f6be5ccdab113&FORMID=987c099fe12995c46059458324632afc&AUDID=1d1b97763e915159f36016c0f46fe0e9&EMAILID=8f9ff131ddf0d93209849360ad83fcf9ed298cefd1667847&DECODE=1&INTID=2dad22db1ebd20fdccc60fd624169bb2&URL=http://www.esri.com/about-esri/contact.html?WT.mc_id=EmailCampaign17055>
Copyright © 2013 Esri. All rights reserved.
Esri, 380 New York Street, Redlands, CA 92373, USA.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130913/e2aa3069/attachment-0001.html>
