[GRASS-user] How to changer map order with line command on a Monitor
Hamish
hamish_b at yahoo.com
Mon Sep 23 16:00:32 PDT 2013
Lucien wrote:
> I would like to know if there is a way to change
> the map order on a Monitor with line command (i.e
> with a d.* command).
Use 'd.save -a > draw.sh' to save the monitor's command
list to a file, then edit that file, and either run (source)
the script or cut & paste to the terminal.
'd.save remove=1,3,5" is also useful for removing commands
from the middle of the stack. the other d.save outputs append
a "# 3" comment to let you know the numbering if there are many.
Hamish
