[GRASS-user] v.in.ascii : ERROR: write sidx
Le Jeune Yann
lj.yann at gmail.com
Thu Sep 26 05:11:38 PDT 2013
Hello,
I have just installed GRASS 7.0 svn 57844 on Linux Mint 15.
v.in.ascii stopped during the build process : "ERROR: write sidx: wrong
node position in file"
Like this :
Scanning input for column types...
Number of columns: 3
Importing points...
100%
Building topology for vector map <PTS_menhir2_pc_88M at menhir2>...
Registering primitives...
88509169 primitives registered
88509169 vertices registered
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
100%
Number of nodes: 0
Number of primitives: 88509169
Number of points: 88509169
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
ERROR: write sidx: wrong node position in file
The command was :
v.in.ascii -z input=${FILE} output=${NAME_OUT} separator="${FS}" z=3
--overwrite
>From a shell script.
Is this a known issue ?
yann
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130926/865426d2/attachment.html>
