[GRASS-user] v.in.ascii : ERROR: write sidx
Le Jeune Yann
lj.yann at gmail.com
Thu Sep 26 08:09:11 PDT 2013
> If you are using a 32bit OS, you might need large file support (LFS)
> which is by default enabled. LFS can but should not be disabled with
> --disable-largefile.
i use a 64 bit system, with LFS
> Do you have enough free disk space?
Yes
> If you do not need topology for the points, you can try v.in.ascii -b.
that works for me, Thanks a lot !!
yann
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130926/244e2fc8/attachment.html>
