[GRASS-user] v.in.ascii : ERROR: write sidx
Le Jeune Yann lj.yann at gmail.com
Thu Sep 26 11:05:42 PDT 2013
Sorry, in Fact i still need topology for further processes,
Any ideas ?
Thanks
yann
2013/9/26 Le Jeune Yann <lj.yann at gmail.com>
>> If you are using a 32bit OS, you might need large file support (LFS)
>> which is by default enabled. LFS can but should not be disabled with
>> --disable-largefile.
> i use a 64 bit system, with LFS
>> Do you have enough free disk space?
> Yes
>> If you do not need topology for the points, you can try v.in.ascii -b.
> that works for me, Thanks a lot !!
> yann
Yann Le Jeune
Web : http://www.paleosystem.fr/ylj_pro/
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130926/ad7ac6fc/attachment.html>
