[GRASS-user] v.in.ascii : ERROR: write sidx
Markus Metz markus.metz.giswork at gmail.com
Thu Sep 26 23:11:11 PDT 2013
Le Jeune Yann wrote:
> ERROR: write sidx: wrong node position in file
> (Fri Sep 27 00:44:28 2013) Command finished (45 min 59 sec)
> I have some disk space, but i looked at my system monitor and my RAM went to
> SWAP (i have only 16 Go RAM, 15 Go SWAP) The swap don't seems to have been
> totally used (but at least half) and i have not in front of my PC when the
> error occurred.
You can try to set the environment variable GRASS_VECTOR_LOWMEM with
export GRASS_VECTOR_LOWMEM=1
This will substantially reduce memory requirements when building
topology, particularly for points. You will need a bit of free disk
space where your grassdata are located.
HTH,
Markus M
> I will try this again with more RAM.
> Thanks for your answers.
> yann
> 2013/9/26 Hamish <hamish_b at yahoo.com>
>> Yann wrote:
>> > The command was :
>> > v.in.ascii -z input=${FILE} output=${NAME_OUT} separator="${FS}" z=3
>> > --overwrite
>> Hi,
>> just to note -- the {curly} brackets do nothing to
>> protect from spaces in filenames in this situation,
>> "double" quotes should be used for that.
>> the curly brackets protect the variable name, not its
>> contents, so are mostly useful for when a letter,
>> number, or "_" follows the variable name.
>> I actually think it is dangerous to use the curly
>> brackets because it tricks people into thinking they
>> are protected when they are not.
>> regards,
>> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
