[GRASS-user] v.in.ascii : ERROR: write sidx
Le Jeune Yann lj.yann at gmail.com
Fri Sep 27 00:21:57 PDT 2013
2013/9/27 Markus Metz <markus.metz.giswork at gmail.com>
> You can try to set the environment variable GRASS_VECTOR_LOWMEM with
> export GRASS_VECTOR_LOWMEM=1
> This will substantially reduce memory requirements when building
> topology, particularly for points. You will need a bit of free disk
> space where your grassdata are located.
> Ok, thanks !
i will try this too.
yann
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130927/e49be3a4/attachment.html>
