[GRASS-user] v.in.ascii : ERROR: write sidx
Le Jeune Yann lj.yann at gmail.com
Mon Sep 30 00:23:37 PDT 2013
I tried r.in.xyz and it's perfect for me.
Thanks a lot !
yann
2013/9/27 Le Jeune Yann <lj.yann at gmail.com>
> 2013/9/27 Markus Metz <markus.metz.giswork at gmail.com>
>> You can try to set the environment variable GRASS_VECTOR_LOWMEM with
>> export GRASS_VECTOR_LOWMEM=1
>> This will substantially reduce memory requirements when building
>> topology, particularly for points. You will need a bit of free disk
>> space where your grassdata are located.
>> Ok, thanks !
> i will try this too.
> yann
Yann Le Jeune
Web : http://www.paleosystem.fr/ylj_pro/
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130930/002113e3/attachment.html>
