[GRASS-user] GRASS GIS 7.0.0beta1 is out
Michael Barton
Michael.Barton at asu.edu
Mon Apr 7 13:53:53 PDT 2014
Adam,
Which version did you try to install? What is your OS? While frameworks did you install?
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Apr 7, 2014, at 6:47 AM, Adam Dershowitz <adershowitz at exponent.com> wrote:
> I just tried to install this. I had a very recent 7.0 of yours installed.
> When I run the installer, it makes it through most of the steps. Then,
> near the end, it says, validating and finally brings up an error.
> Here is what shows in the box:
> There were errors with the installation. You may want to try (then the
> message is cut off).
> The installation failed.
> The installer encountered n error that caused the installation to tail.
> Contact the software manufacturer for assistance.
> The install log is below:
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: LSExceptions
> [0x6080000b9380] loaded
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: @(#)PROGRAM:Install
> PROJECT:Install-846
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: @(#)PROGRAM:Installer
> PROJECT:Installer-721
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Hardware: MacBookPro9,1
> @ 2.60 GHz (x 8), 8192 MB RAM
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Running OS Build: Mac
> OS X 10.9.2 (13C64)
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env:
> PATH=/usr/bin:/bin:/usr/sbin:/sbin
> TMPDIR=/var/folders/s4/0j3cshj161126ygbpbzsdkmd4h24dl/T/
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: SHELL=/bin/bash
> HOME=/Users/adershowitz
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: USER=adershowitz
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: LOGNAME=adershowitz
> GPG_AGENT_INFO=/Users/adershowitz/.gnupg/S.gpg-agent:634:1
> SSH_AUTH_SOCK=/tmp/launch-cRtteu/Listeners
> Apple_PubSub_Socket_Render=/tmp/launch-YoZwJc/Render
> DISPLAY=/tmp/launch-UzS5ph/org.macosforge.xquartz:0
> DBUS_LAUNCHD_SESSION_BUS_SOCKET=/tmp/launch-LKGofO/unix_domain_listener
> __CF_USER_TEXT_ENCODING=0x490111B3:0:0
> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: __CHECKFIX1436934=1
> Apr 7 09:39:02 adershowitzMBP15 Installer[57796]: GRASS-7.0 Installation
> Log
> Apr 7 09:39:02 adershowitzMBP15 Installer[57796]: Opened from:
> /Users/adershowitz/Downloads/Navigate etc/GRASS-7.0beta1.pkg
> Apr 7 09:39:03 adershowitzMBP15 Installer[57796]: Referenced component
> packages (1) trustLevel=100
> Apr 7 09:39:13 adershowitzMBP15 Installer[57796]: LSExceptions
> [0x6080000b9380] unloaded
> Apr 7 09:39:34 adershowitzMBP15 Installer[57796]:
> InstallerStatusNotifications plugin loaded
> Apr 7 09:39:42 adershowitzMBP15 runner[57801]: Administrator
> authorization granted.
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]:
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: User picked Standard
> Install
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Choices selected for
> installation:
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Upgrade: "GRASS-7.0"
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: GRASS-7.0beta1.pkg :
> org.osgeo.grass7_0 : 7.0.140403.7.0
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: It took 0.00 seconds to
> summarize the package selections.
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: -[IFPKGDerivedDocument
> sortedPackageLocations]: result = (
> "file://localhost"
> -[IFDInstallController(Private) _buildInstallPlan]: location =
> file://localhost
> file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0beta1.
> pkg
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Set authorization level
> to root for session
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Will use PK session
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Starting installation:
> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Configuring volume
> "Macintosh HD"
> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Preparing disk for
> local booted install.
> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Free space on
> "Macintosh HD": 121.37 GB (121369862144 bytes).
> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Create temporary
> directory
> "/var/folders/s4/0j3cshj161126ygbpbzsdkmd4h24dl/T//Install.577965qM2wZ"
> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: IFPKInstallElement (1
> packages)
> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Using authorization
> level of root for IFPKInstallElement
> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Adding
> client PKInstallDaemonClient pid=57796, uid=1224806835
> (/System/Library/CoreServices/Installer.app/Contents/MacOS/Installer)
> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: PackageKit: Enqueuing
> install with boosting
> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: ----- Begin
> install -----
> request=PKInstallRequest <1 packages, destination=/>
> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: packages=(
> "PKJaguarPackage
> <file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0beta1
> .pkg>"
> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Will do
> receipt-based obsoleting for package identifier org.osgeo.grass7_0 (prefix
> path=Applications/GRASS)
> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Extracting
> pkg
> (destination=/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSand
> boxManager/E4657E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.activeSandbox/Root/Applicat
> ions/GRASS, uid=0)
> Apr 7 09:40:14 adershowitzMBP15 installd[48393]: PackageKit: prevent user
> idle system sleep
> Apr 7 09:40:14 adershowitzMBP15 installd[48393]: PackageKit: suspending
> backupd
> Apr 7 09:40:15 adershowitzMBP15 install_monitor[57819]: Temporarily
> excluding: /Applications, /Library, /System, /bin, /private, /sbin, /usr
> Apr 7 09:40:20 adershowitzMBP15 installd[48393]: PackageKit: Using
> trashcan path
> /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/PKInstallSandboxTrash/E465
> 7E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.sandboxTrash for sandbox
> /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/E4
> Apr 7 09:40:20 adershowitzMBP15 installd[48393]: PackageKit: Shoving
> 657E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.activeSandbox/Root (1 items) to /
> Apr 7 09:40:26 adershowitzMBP15 installd[48393]: PackageKit: Executing
> script "./postflight" in /Users/adershowitz/Downloads/Navigate
> etc/GRASS-7.0beta1.pkg/Contents/Resources
> Apr 7 09:40:26 adershowitzMBP15 installd[48393]: PackageKit: *** launch
> path not accessible
> Apr 7 09:40:26 adershowitzMBP15 install_monitor[57819]: Re-included:
> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: releasing
> backupd
> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: allow user
> idle system sleep
> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Install
> Failed: Error Domain=PKInstallErrorDomain Code=112 "An error occurred
> while running scripts from the package ³GRASS-7.0beta1.pkg²."
> UserInfo=0x7fcf8b60a540 {NSFilePath=./postflight,
> NSURL=file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0
> beta1.pkg, PKInstallPackageIdentifier=org.osgeo.grass7_0,
> NSLocalizedDescription=An error occurred while running scripts from the
> package ³GRASS-7.0beta1.pkg².} {
> NSFilePath = "./postflight";
> NSLocalizedDescription = "An error occurred while running scripts
> from the package \U201cGRASS-7.0beta1.pkg\U201d.";
> NSURL =
> "file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0beta1
> .pkg";
> PKInstallPackageIdentifier = "org.osgeo.grass7_0";
> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]:
> install:didFailWithError:Error Domain=PKInstallErrorDomain Code=112 "An
> error occurred while running scripts from the package
> ³GRASS-7.0beta1.pkg²." UserInfo=0x6100000eb400 {NSFilePath=./postflight,
> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Running idle
> tasks
> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Removing
> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Done with
> sandbox removals
> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: Install failed: The
> Installer encountered an error that caused the installation to fail.
> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: IFDInstallController
> 2E30 state = 8
> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: Displaying 'Install
> Failed' UI.
> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: 'Install Failed' UI
> displayed message:'The Installer encountered an error that caused the
> installation to fail. Contact the software manufacturer for assistance.'.
> Thanks, and any thoughts or suggestions are appreciated.
> -- Adam
> On 4/3/14, 7:30 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>> I compiled the new GRASS 7 beta1 from the current release branch and
>> posted it to the http://grassmac.wikidot.com web site. In order to make
>> this available as soon as possible, I have had to compile it without LAS
>> tools and without gettext internationalization support. If you install
>> this,IT WILL OVERWRITE YOUR EXISTING GRASS 7 INSTALLATION unless you move
>> GRASS 7 out of the /Applications/Grass folder.
>> Michael
>> C. Michael Barton
>> USA
>> On Mar 30, 2014, at 1:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>> Dear Packagers,
>>> (pls fwd if I forgot to cc a packager)
>>> after almost 6 years of development, a first 7.0.0beta1 is out:
>>> http://grass.osgeo.org/grass70/source/grass-7.0.0beta1.tar.gz
>>> http://grass.osgeo.org/grass70/source/grass-7.0.0beta1.md5sum
>>> Could you please provide an updated installer for your distro?
>>> (note: winGRASS standalone is already there)
>>> I'm still completing the announcement at
>>> http://trac.osgeo.org/grass/wiki/Release/7.0.0beta-News
>>> and other places (feel free to improve the pages).
>>> on behalf of all GRASS GIS users,
>>> thanks
>>> Markus
>>> PS: known potential packaging issue with patch suggestion:
>>> http://trac.osgeo.org/grass/ticket/1839
>>> http://courses.neteler.org/
>>> http://gis.cri.fmach.it/neteler/
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
