[GRASS-user] GRASS GIS 7.0.0beta1 is out
Adam Dershowitz
adershowitz at exponent.com
Mon Apr 7 14:06:03 PDT 2014
I tried to install 7.0.0beta1, that I downloaded today. I have OS 10.9.2
I didn’t upgrade or change any frameworks, but I have the set that I had
upgraded from kyngchaos.com a few weeks ago. And that set was working
fine with a very recent 7.0 from your site, and a recent 6.4 from
Kyngchaos.
Does the installer now try to verify some frameworks are present?
-- Adam
On 4/7/14, 4:53 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>Adam,
>Which version did you try to install? What is your OS? While frameworks
>did you install?
>Michael
>______________________________
>C. Michael Barton
>Director, Center for Social Dynamics & Complexity
>Professor of Anthropology, School of Human Evolution & Social Change
>Head, Graduate Faculty in Complex Adaptive Systems Science
>Arizona State University
>Tempe, AZ 85287-2402
>USA
>voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
>www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
>On Apr 7, 2014, at 6:47 AM, Adam Dershowitz <adershowitz at exponent.com>
>wrote:
>> I just tried to install this. I had a very recent 7.0 of yours
>>installed.
>> When I run the installer, it makes it through most of the steps. Then,
>> near the end, it says, validating and finally brings up an error.
>> Here is what shows in the box:
>> There were errors with the installation. You may want to try (then the
>> message is cut off).
>> The installation failed.
>> The installer encountered n error that caused the installation to tail.
>> Contact the software manufacturer for assistance.
>> The install log is below:
>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: LSExceptions
>> [0x6080000b9380] loaded
>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: @(#)PROGRAM:Install
>> PROJECT:Install-846
>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: @(#)PROGRAM:Installer
>> PROJECT:Installer-721
>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Hardware:
>>MacBookPro9,1
>> @ 2.60 GHz (x 8), 8192 MB RAM
>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Running OS Build: Mac
>> OS X 10.9.2 (13C64)
>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env:
>> PATH=/usr/bin:/bin:/usr/sbin:/sbin
>> TMPDIR=/var/folders/s4/0j3cshj161126ygbpbzsdkmd4h24dl/T/
>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: SHELL=/bin/bash
>> HOME=/Users/adershowitz
>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: USER=adershowitz
>>LOGNAME=adershowitz
>> GPG_AGENT_INFO=/Users/adershowitz/.gnupg/S.gpg-agent:634:1
>> SSH_AUTH_SOCK=/tmp/launch-cRtteu/Listeners
>> Apple_PubSub_Socket_Render=/tmp/launch-YoZwJc/Render
>> DISPLAY=/tmp/launch-UzS5ph/org.macosforge.xquartz:0
>> DBUS_LAUNCHD_SESSION_BUS_SOCKET=/tmp/launch-LKGofO/unix_domain_listener
>> __CF_USER_TEXT_ENCODING=0x490111B3:0:0
>>__CHECKFIX1436934=1
>> Apr 7 09:39:02 adershowitzMBP15 Installer[57796]: GRASS-7.0
>>Installation
>> Log
>> Apr 7 09:39:02 adershowitzMBP15 Installer[57796]: Opened from:
>> /Users/adershowitz/Downloads/Navigate etc/GRASS-7.0beta1.pkg
>> Apr 7 09:39:03 adershowitzMBP15 Installer[57796]: Referenced component
>> packages (1) trustLevel=100
>> Apr 7 09:39:13 adershowitzMBP15 Installer[57796]: LSExceptions
>> [0x6080000b9380] unloaded
>> Apr 7 09:39:34 adershowitzMBP15 Installer[57796]:
>> InstallerStatusNotifications plugin loaded
>> Apr 7 09:39:42 adershowitzMBP15 runner[57801]: Administrator
>> authorization granted.
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]:
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: User picked Standard
>> Install
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Choices selected for
>> installation:
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Upgrade: "GRASS-7.0"
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: GRASS-7.0beta1.pkg
>> org.osgeo.grass7_0 : 7.0.140403.7.0
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: It took 0.00 seconds
>>to
>> summarize the package selections.
>>-[IFPKGDerivedDocument
>> sortedPackageLocations]: result = (
>> "file://localhost"
>> -[IFDInstallController(Private) _buildInstallPlan]: location =
>> file://localhost
>>file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0beta
>>1.
>> pkg
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Set authorization
>>level
>> to root for session
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Will use PK session
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Starting
>>installation:
>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Configuring volume
>> "Macintosh HD"
>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Preparing disk for
>> local booted install.
>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Free space on
>> "Macintosh HD": 121.37 GB (121369862144 bytes).
>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Create temporary
>> directory
>> "/var/folders/s4/0j3cshj161126ygbpbzsdkmd4h24dl/T//Install.577965qM2wZ"
>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: IFPKInstallElement (1
>> packages)
>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Using authorization
>> level of root for IFPKInstallElement
>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Adding
>> client PKInstallDaemonClient pid=57796, uid=1224806835
>> (/System/Library/CoreServices/Installer.app/Contents/MacOS/Installer)
>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: PackageKit: Enqueuing
>> install with boosting
>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: -----
>>Begin
>> install -----
>> request=PKInstallRequest <1 packages, destination=/>
>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: packages=(
>> "PKJaguarPackage
>><file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0bet
>>a1
>> .pkg>"
>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Will do
>> receipt-based obsoleting for package identifier org.osgeo.grass7_0
>>(prefix
>> path=Applications/GRASS)
>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Extracting
>>1.
>> pkg
>>(destination=/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSa
>>nd
>>boxManager/E4657E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.activeSandbox/Root/Applic
>>at
>> ions/GRASS, uid=0)
>> Apr 7 09:40:14 adershowitzMBP15 installd[48393]: PackageKit: prevent
>>user
>> idle system sleep
>> Apr 7 09:40:14 adershowitzMBP15 installd[48393]: PackageKit: suspending
>> backupd
>> Apr 7 09:40:15 adershowitzMBP15 install_monitor[57819]: Temporarily
>> excluding: /Applications, /Library, /System, /bin, /private, /sbin, /usr
>> Apr 7 09:40:20 adershowitzMBP15 installd[48393]: PackageKit: Using
>> trashcan path
>>/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/PKInstallSandboxTrash/E4
>>65
>> 7E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.sandboxTrash for sandbox
>>/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/
>>E4
>> Apr 7 09:40:20 adershowitzMBP15 installd[48393]: PackageKit: Shoving
>>E4
>> 657E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.activeSandbox/Root (1 items) to /
>> Apr 7 09:40:26 adershowitzMBP15 installd[48393]: PackageKit: Executing
>> script "./postflight" in /Users/adershowitz/Downloads/Navigate
>> etc/GRASS-7.0beta1.pkg/Contents/Resources
>> Apr 7 09:40:26 adershowitzMBP15 installd[48393]: PackageKit: *** launch
>> path not accessible
>> Apr 7 09:40:26 adershowitzMBP15 install_monitor[57819]: Re-included:
>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: releasing
>> backupd
>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: allow user
>> idle system sleep
>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Install
>> Failed: Error Domain=PKInstallErrorDomain Code=112 "An error occurred
>> while running scripts from the package ³GRASS-7.0beta1.pkg²."
>> UserInfo=0x7fcf8b60a540 {NSFilePath=./postflight,
>>NSURL=file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7
>>.0
>> beta1.pkg, PKInstallPackageIdentifier=org.osgeo.grass7_0,
>> NSLocalizedDescription=An error occurred while running scripts from the
>> package ³GRASS-7.0beta1.pkg².} {
>> NSFilePath = "./postflight";
>> NSLocalizedDescription = "An error occurred while running scripts
>> from the package \U201cGRASS-7.0beta1.pkg\U201d.";
>> NSURL =
>>"file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0bet
>>a1
>> .pkg";
>> PKInstallPackageIdentifier = "org.osgeo.grass7_0";
>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]:
>> install:didFailWithError:Error Domain=PKInstallErrorDomain Code=112 "An
>> error occurred while running scripts from the package
>> ³GRASS-7.0beta1.pkg²." UserInfo=0x6100000eb400 {NSFilePath=./postflight,
>>.0
>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Running
>>idle
>> tasks
>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Removing
>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Done with
>> sandbox removals
>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: Install failed: The
>> Installer encountered an error that caused the installation to fail.
>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: IFDInstallController
>> 2E30 state = 8
>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: Displaying 'Install
>> Failed' UI.
>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: 'Install Failed' UI
>> displayed message:'The Installer encountered an error that caused the
>> installation to fail. Contact the software manufacturer for
>>assistance.'.
>> Thanks, and any thoughts or suggestions are appreciated.
>> -- Adam
>> On 4/3/14, 7:30 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>>> I compiled the new GRASS 7 beta1 from the current release branch and
>>> posted it to the http://grassmac.wikidot.com web site. In order to make
>>> this available as soon as possible, I have had to compile it without
>>>LAS
>>> tools and without gettext internationalization support. If you install
>>> this,IT WILL OVERWRITE YOUR EXISTING GRASS 7 INSTALLATION unless you
>>>move
>>> GRASS 7 out of the /Applications/Grass folder.
>>> Michael
>>> C. Michael Barton
>>> USA
>>> On Mar 30, 2014, at 1:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>>> Dear Packagers,
>>>> (pls fwd if I forgot to cc a packager)
>>>> after almost 6 years of development, a first 7.0.0beta1 is out:
>>>> http://grass.osgeo.org/grass70/source/grass-7.0.0beta1.tar.gz
>>>> http://grass.osgeo.org/grass70/source/grass-7.0.0beta1.md5sum
>>>> Could you please provide an updated installer for your distro?
>>>> (note: winGRASS standalone is already there)
>>>> I'm still completing the announcement at
>>>> http://trac.osgeo.org/grass/wiki/Release/7.0.0beta-News
>>>> and other places (feel free to improve the pages).
>>>> on behalf of all GRASS GIS users,
>>>> thanks
>>>> Markus
>>>> PS: known potential packaging issue with patch suggestion:
>>>> http://trac.osgeo.org/grass/ticket/1839
>>>> http://courses.neteler.org/
>>>> http://gis.cri.fmach.it/neteler/
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
