[GRASS-user] GRASS GIS 7.0.0beta1 is out
Michael Barton
Michael.Barton at asu.edu
Mon Apr 7 14:15:54 PDT 2014
I was able to replicate this. I’ll have to try recompiling. I have no idea what is wrong.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Apr 7, 2014, at 2:06 PM, Adam Dershowitz <adershowitz at exponent.com> wrote:
> I tried to install 7.0.0beta1, that I downloaded today. I have OS 10.9.2
> I didn’t upgrade or change any frameworks, but I have the set that I had
> upgraded from kyngchaos.com a few weeks ago. And that set was working
> fine with a very recent 7.0 from your site, and a recent 6.4 from
> Kyngchaos.
> Does the installer now try to verify some frameworks are present?
> -- Adam
> On 4/7/14, 4:53 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>> Adam,
>> Which version did you try to install? What is your OS? While frameworks
>> did you install?
>> Michael
>> C. Michael Barton
>> USA
>> On Apr 7, 2014, at 6:47 AM, Adam Dershowitz <adershowitz at exponent.com>
>> wrote:
>>> I just tried to install this. I had a very recent 7.0 of yours
>>> installed.
>>> When I run the installer, it makes it through most of the steps. Then,
>>> near the end, it says, validating and finally brings up an error.
>>> Here is what shows in the box:
>>> There were errors with the installation. You may want to try (then the
>>> message is cut off).
>>> The installation failed.
>>> The installer encountered n error that caused the installation to tail.
>>> Contact the software manufacturer for assistance.
>>> The install log is below:
>>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: LSExceptions
>>> [0x6080000b9380] loaded
>>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: @(#)PROGRAM:Install
>>> PROJECT:Install-846
>>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: @(#)PROGRAM:Installer
>>> PROJECT:Installer-721
>>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Hardware:
>>> MacBookPro9,1
>>> @ 2.60 GHz (x 8), 8192 MB RAM
>>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Running OS Build: Mac
>>> OS X 10.9.2 (13C64)
>>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env:
>>> PATH=/usr/bin:/bin:/usr/sbin:/sbin
>>> TMPDIR=/var/folders/s4/0j3cshj161126ygbpbzsdkmd4h24dl/T/
>>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: SHELL=/bin/bash
>>> HOME=/Users/adershowitz
>>> Apr 7 09:39:01 adershowitzMBP15 Installer[57796]: Env: USER=adershowitz
>>> LOGNAME=adershowitz
>>> GPG_AGENT_INFO=/Users/adershowitz/.gnupg/S.gpg-agent:634:1
>>> SSH_AUTH_SOCK=/tmp/launch-cRtteu/Listeners
>>> Apple_PubSub_Socket_Render=/tmp/launch-YoZwJc/Render
>>> DISPLAY=/tmp/launch-UzS5ph/org.macosforge.xquartz:0
>>> DBUS_LAUNCHD_SESSION_BUS_SOCKET=/tmp/launch-LKGofO/unix_domain_listener
>>> __CF_USER_TEXT_ENCODING=0x490111B3:0:0
>>> __CHECKFIX1436934=1
>>> Apr 7 09:39:02 adershowitzMBP15 Installer[57796]: GRASS-7.0
>>> Installation
>>> Log
>>> Apr 7 09:39:02 adershowitzMBP15 Installer[57796]: Opened from:
>>> /Users/adershowitz/Downloads/Navigate etc/GRASS-7.0beta1.pkg
>>> Apr 7 09:39:03 adershowitzMBP15 Installer[57796]: Referenced component
>>> packages (1) trustLevel=100
>>> Apr 7 09:39:13 adershowitzMBP15 Installer[57796]: LSExceptions
>>> [0x6080000b9380] unloaded
>>> Apr 7 09:39:34 adershowitzMBP15 Installer[57796]:
>>> InstallerStatusNotifications plugin loaded
>>> Apr 7 09:39:42 adershowitzMBP15 runner[57801]: Administrator
>>> authorization granted.
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]:
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: User picked Standard
>>> Install
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Choices selected for
>>> installation:
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Upgrade: "GRASS-7.0"
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: GRASS-7.0beta1.pkg
>>> org.osgeo.grass7_0 : 7.0.140403.7.0
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: It took 0.00 seconds
>>> to
>>> summarize the package selections.
>>> -[IFPKGDerivedDocument
>>> sortedPackageLocations]: result = (
>>> "file://localhost"
>>> -[IFDInstallController(Private) _buildInstallPlan]: location =
>>> file://localhost
>>> file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0beta
>>> 1.
>>> pkg
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Set authorization
>>> level
>>> to root for session
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Will use PK session
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Starting
>>> installation:
>>> Apr 7 09:39:42 adershowitzMBP15 Installer[57796]: Configuring volume
>>> "Macintosh HD"
>>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Preparing disk for
>>> local booted install.
>>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Free space on
>>> "Macintosh HD": 121.37 GB (121369862144 bytes).
>>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Create temporary
>>> directory
>>> "/var/folders/s4/0j3cshj161126ygbpbzsdkmd4h24dl/T//Install.577965qM2wZ"
>>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: IFPKInstallElement (1
>>> packages)
>>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: Using authorization
>>> level of root for IFPKInstallElement
>>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Adding
>>> client PKInstallDaemonClient pid=57796, uid=1224806835
>>> (/System/Library/CoreServices/Installer.app/Contents/MacOS/Installer)
>>> Apr 7 09:39:43 adershowitzMBP15 Installer[57796]: PackageKit: Enqueuing
>>> install with boosting
>>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: -----
>>> Begin
>>> install -----
>>> request=PKInstallRequest <1 packages, destination=/>
>>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: packages=(
>>> "PKJaguarPackage
>>> <file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0bet
>>> a1
>>> .pkg>"
>>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Will do
>>> receipt-based obsoleting for package identifier org.osgeo.grass7_0
>>> (prefix
>>> path=Applications/GRASS)
>>> Apr 7 09:39:43 adershowitzMBP15 installd[48393]: PackageKit: Extracting
>>> 1.
>>> pkg
>>> (destination=/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSa
>>> nd
>>> boxManager/E4657E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.activeSandbox/Root/Applic
>>> at
>>> ions/GRASS, uid=0)
>>> Apr 7 09:40:14 adershowitzMBP15 installd[48393]: PackageKit: prevent
>>> user
>>> idle system sleep
>>> Apr 7 09:40:14 adershowitzMBP15 installd[48393]: PackageKit: suspending
>>> backupd
>>> Apr 7 09:40:15 adershowitzMBP15 install_monitor[57819]: Temporarily
>>> excluding: /Applications, /Library, /System, /bin, /private, /sbin, /usr
>>> Apr 7 09:40:20 adershowitzMBP15 installd[48393]: PackageKit: Using
>>> trashcan path
>>> /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/PKInstallSandboxTrash/E4
>>> 65
>>> 7E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.sandboxTrash for sandbox
>>> /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/
>>> E4
>>> Apr 7 09:40:20 adershowitzMBP15 installd[48393]: PackageKit: Shoving
>>> E4
>>> 657E3B-0CFE-48D5-B3F5-BBA5ABA8E7A7.activeSandbox/Root (1 items) to /
>>> Apr 7 09:40:26 adershowitzMBP15 installd[48393]: PackageKit: Executing
>>> script "./postflight" in /Users/adershowitz/Downloads/Navigate
>>> etc/GRASS-7.0beta1.pkg/Contents/Resources
>>> Apr 7 09:40:26 adershowitzMBP15 installd[48393]: PackageKit: *** launch
>>> path not accessible
>>> Apr 7 09:40:26 adershowitzMBP15 install_monitor[57819]: Re-included:
>>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: releasing
>>> backupd
>>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: allow user
>>> idle system sleep
>>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Install
>>> Failed: Error Domain=PKInstallErrorDomain Code=112 "An error occurred
>>> while running scripts from the package ³GRASS-7.0beta1.pkg²."
>>> UserInfo=0x7fcf8b60a540 {NSFilePath=./postflight,
>>> NSURL=file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7
>>> .0
>>> beta1.pkg, PKInstallPackageIdentifier=org.osgeo.grass7_0,
>>> NSLocalizedDescription=An error occurred while running scripts from the
>>> package ³GRASS-7.0beta1.pkg².} {
>>> NSFilePath = "./postflight";
>>> NSLocalizedDescription = "An error occurred while running scripts
>>> from the package \U201cGRASS-7.0beta1.pkg\U201d.";
>>> NSURL =
>>> "file://localhost/Users/adershowitz/Downloads/Navigate%20etc/GRASS-7.0bet
>>> a1
>>> .pkg";
>>> PKInstallPackageIdentifier = "org.osgeo.grass7_0";
>>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]:
>>> install:didFailWithError:Error Domain=PKInstallErrorDomain Code=112 "An
>>> error occurred while running scripts from the package
>>> ³GRASS-7.0beta1.pkg²." UserInfo=0x6100000eb400 {NSFilePath=./postflight,
>>> .0
>>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Running
>>> idle
>>> tasks
>>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Removing
>>> Apr 7 09:40:27 adershowitzMBP15 installd[48393]: PackageKit: Done with
>>> sandbox removals
>>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: Install failed: The
>>> Installer encountered an error that caused the installation to fail.
>>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: IFDInstallController
>>> 2E30 state = 8
>>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: Displaying 'Install
>>> Failed' UI.
>>> Apr 7 09:40:27 adershowitzMBP15 Installer[57796]: 'Install Failed' UI
>>> displayed message:'The Installer encountered an error that caused the
>>> installation to fail. Contact the software manufacturer for
>>> assistance.'.
>>> Thanks, and any thoughts or suggestions are appreciated.
>>> -- Adam
>>> On 4/3/14, 7:30 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>>>> I compiled the new GRASS 7 beta1 from the current release branch and
>>>> posted it to the http://grassmac.wikidot.com web site. In order to make
>>>> this available as soon as possible, I have had to compile it without
>>>> LAS
>>>> tools and without gettext internationalization support. If you install
>>>> this,IT WILL OVERWRITE YOUR EXISTING GRASS 7 INSTALLATION unless you
>>>> move
>>>> GRASS 7 out of the /Applications/Grass folder.
>>>> Michael
>>>> C. Michael Barton
>>>> USA
>>>> On Mar 30, 2014, at 1:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>>>> Dear Packagers,
>>>>> (pls fwd if I forgot to cc a packager)
>>>>> after almost 6 years of development, a first 7.0.0beta1 is out:
>>>>> http://grass.osgeo.org/grass70/source/grass-7.0.0beta1.tar.gz
>>>>> http://grass.osgeo.org/grass70/source/grass-7.0.0beta1.md5sum
>>>>> Could you please provide an updated installer for your distro?
>>>>> (note: winGRASS standalone is already there)
>>>>> I'm still completing the announcement at
>>>>> http://trac.osgeo.org/grass/wiki/Release/7.0.0beta-News
>>>>> and other places (feel free to improve the pages).
>>>>> on behalf of all GRASS GIS users,
>>>>> thanks
>>>>> Markus
>>>>> PS: known potential packaging issue with patch suggestion:
>>>>> http://trac.osgeo.org/grass/ticket/1839
>>>>> http://courses.neteler.org/
>>>>> http://gis.cri.fmach.it/neteler/
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
