[GRASS-user] Help needed for ascii point export
jctorres jctorres at ugr.es
Mon Apr 14 23:13:57 PDT 2014
Hello
You can create a map of these points contining the elevation as
attribute. Once you output this map you could sort points using the
elevation values.
you can do this for instance using v.to.rast to convert the points to
raster, them combine this map with elevation using r.mapcalc (assigning
elevation to the points), and them output the map using r.out.xyz.
To sort the points you can use any sort program or a spreadsheet.
Best regards
Juan Carlos Torres
El 15/04/14 04:52, Thomas Adams escribió:
> All:
> I have a collection of points that represent the centerline of a
> river. I need to output them in upstream to downstream order (or the
> reverse). A simple v.out.ascii does not do this because of the channel
> meanders. It's critical to get the x,y locations of these points in
> the correct order.
> Any help is appreciated!
> Regards,
> Tom
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
Juan Carlos Torres                      | http://lsi.ugr.es/~jctorres
Laboratorio de Realidad Virtual         | Tlf.: (+34) 645 885 167
Dpto. Lenguajes y Sistemas Informaticos |       (+34) 958 249 307
ETS. Ing. Informatica                   |     interno ugr  71 260
Univ. de Granada                        | FAX: (+34) 958 243 179
------------ pr?xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140415/3ed17d92/attachment.html>
