[GRASS-user] Errors running r.inund.fluv
Thomas Adams
tea3rd at gmail.com
Fri Apr 18 15:06:27 PDT 2014
Marcus,
Yes; when I run ls $GISBASE/etc/fortran_code/ I get all of those:
2d_path* clean_inundation* correction_from_path* dati.mod* dd.mod*
find_main_channel*
So, do you think I should build 6.4.svn and should probably use this?
Regards,
Tom
On Fri, Apr 18, 2014 at 4:29 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Apr 18, 2014 at 9:55 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> > I have output errors from running r.inund.fluv using GRASS 6.4.3. on
> Ubuntu
> > 13.10 none of my output maps were written successfully; my DEM is coarse
> > (30m). But below is what I am getting in term window output -- much more
> > detail in the Command Window output, which I can provide.
> > Regards,
> > Tom
> > GRASS 6.4.3 (potomac_utm):~/grass/data > r.inund.fluv
> > GRASS_INFO_WARNING(25914,1): Table <limiti_alveo> not found in database
> > </home/teaiii/grass/data/potomac_utm/teaiii/sqlite/sqlite.db> using
> driver
> > <sqlite>
> Some part of the Addon is written in Fortran, did you compile all of
> those binaries?
> Requires gfortran or the like to be present on the system at compile time.
> To check, run this in a GRASS 6.4 session:
> It should list:
> find_main_channel*
> Some of those probably create the table which isn't found in your
> sqlite.db.
> Markus
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140418/da903553/attachment.html>
