[GRASS-user] Errors running r.inund.fluv
Markus Neteler neteler at osgeo.org
Sat Apr 19 03:41:54 PDT 2014
On Sat, Apr 19, 2014 at 12:06 AM, Thomas Adams <tea3rd at gmail.com> wrote:
> Marcus,
> Yes; when I run ls $GISBASE/etc/fortran_code/ I get all of those:
> 2d_path*  clean_inundation*  correction_from_path*  dati.mod*  dd.mod*
> find_main_channel*
ok, so the installation seems to be complete.
> So, do you think I should build 6.4.svn and should probably use this?
Well, that was only meant to test the updated g.extension.py.
Re: r.inund.fluv it may be the best to contact the authors since it is an addon.
Best
Markus
