[GRASS-user] Here is the detailed output I'm getting from r.inund.fluv
Thomas Adams
tea3rd at gmail.com
Sat Apr 19 12:23:34 PDT 2014
All:
Below is the detailed output I'm getting from running r.inund.fluv on
Ubuntu 13.10, GRASS 6.4.3.
My DTM is 30m x 30m (the best I can do at the moment) and distances between
cross-sections is on the order of 300-500 meters -- could this explain my
results (no maps are created)?
Regards,
Tom
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140419/7b9a51d3/attachment.html>
(Sat Apr 19 14:57:19 2014)
r.inund.fluv --overwrite DTM=chesapeake_final at teaiii W_S_PROFILE=/home/teaiii/Documents/Climate Decision LLC/upper_potomac_up2down.txt RIVER=potomac_river at teaiii FLOODING_MAP=potomac_inund
/usr/local/grass-6.4.3/scripts/r.inund.fluv: 162: [: Illegal
number: 29.99957802
The DTM resolution is 29.99957802 x 29.99957802 meters
WARNING: Raster map <MASK> not found
WARNING: <MASK> nothing removed
region2.txt
4428236.00 4099080.75 414639.531 233037.875 29.9995785 10972 6053
Fortran code that automatically find bed river
There are 63283233 no-null cells in Digital Terrain Model
Read the Digital Terrain Model with Compressed Sparse Row (CSR) algorithm
Read 73 rows in file of water surface
In 1 section NO right boundary ~ SEE THE PARAMETER
In 1 section NO left boundary ~ SEE THE PARAMETER
In 2 section NO right boundary ~ SEE THE PARAMETER
In 2 section NO left boundary ~ SEE THE PARAMETER
In 3 section NO right boundary ~ SEE THE PARAMETER
In 3 section NO left boundary ~ SEE THE PARAMETER
In 4 section NO left boundary ~ SEE THE PARAMETER
In 5 section NO right boundary ~ SEE THE PARAMETER
In 5 section NO left boundary ~ SEE THE PARAMETER
In 6 section NO right boundary ~ SEE THE PARAMETER
In 6 section NO left boundary ~ SEE THE PARAMETER
In 7 section NO right boundary ~ SEE THE PARAMETER
In 7 section NO left boundary ~ SEE THE PARAMETER
In 8 section NO right boundary ~ SEE THE PARAMETER
In 8 section NO left boundary ~ SEE THE PARAMETER
In 9 section NO right boundary ~ SEE THE PARAMETER
In 9 section NO left boundary ~ SEE THE PARAMETER
In 10 section NO right boundary ~ SEE THE PARAMETER
In 10 section NO left boundary ~ SEE THE PARAMETER
In 11 section NO right boundary ~ SEE THE PARAMETER
In 11 section NO left boundary ~ SEE THE PARAMETER
In 12 section NO right boundary ~ SEE THE PARAMETER
In 12 section NO left boundary ~ SEE THE PARAMETER
In 13 section NO right boundary ~ SEE THE PARAMETER
In 13 section NO left boundary ~ SEE THE PARAMETER
In 14 section NO right boundary ~ SEE THE PARAMETER
In 14 section NO left boundary ~ SEE THE PARAMETER
In 15 section NO right boundary ~ SEE THE PARAMETER
In 15 section NO left boundary ~ SEE THE PARAMETER
In 16 section NO right boundary ~ SEE THE PARAMETER
In 16 section NO left boundary ~ SEE THE PARAMETER
In 18 section NO left boundary ~ SEE THE PARAMETER
In 20 section NO left boundary ~ SEE THE PARAMETER
In 21 section NO right boundary ~ SEE THE PARAMETER
In 22 section NO left boundary ~ SEE THE PARAMETER
In 23 section NO left boundary ~ SEE THE PARAMETER
In 24 section NO right boundary ~ SEE THE PARAMETER
In 24 section NO left boundary ~ SEE THE PARAMETER
In 25 section NO right boundary ~ SEE THE PARAMETER
In 26 section NO right boundary ~ SEE THE PARAMETER
In 26 section NO left boundary ~ SEE THE PARAMETER
In 27 section NO right boundary ~ SEE THE PARAMETER
In 28 section NO right boundary ~ SEE THE PARAMETER
In 28 section NO left boundary ~ SEE THE PARAMETER
In 29 section NO right boundary ~ SEE THE PARAMETER
In 29 section NO left boundary ~ SEE THE PARAMETER
In 30 section NO left boundary ~ SEE THE PARAMETER
In 31 section NO right boundary ~ SEE THE PARAMETER
In 33 section NO right boundary ~ SEE THE PARAMETER
In 34 section NO right boundary ~ SEE THE PARAMETER
In 35 section NO right boundary ~ SEE THE PARAMETER
In 36 section NO left boundary ~ SEE THE PARAMETER
In 37 section NO right boundary ~ SEE THE PARAMETER
In 37 section NO left boundary ~ SEE THE PARAMETER
In 38 section NO right boundary ~ SEE THE PARAMETER
In 38 section NO left boundary ~ SEE THE PARAMETER
In 39 section NO right boundary ~ SEE THE PARAMETER
In 39 section NO left boundary ~ SEE THE PARAMETER
In 40 section the boundary of river is out of DTM
In 40 section NO left boundary ~ SEE THE PARAMETER
In 41 section NO right boundary ~ SEE THE PARAMETER
In 41 section NO left boundary ~ SEE THE PARAMETER
In 43 section NO right boundary ~ SEE THE PARAMETER
In 43 section NO left boundary ~ SEE THE PARAMETER
In 44 section NO left boundary ~ SEE THE PARAMETER
In 46 section the boundary of river is out of DTM
In 48 section the boundary of river is out of DTM
In 48 section NO left boundary ~ SEE THE PARAMETER
In 49 section NO right boundary ~ SEE THE PARAMETER
In 49 section NO left boundary ~ SEE THE PARAMETER
In 50 section NO right boundary ~ SEE THE PARAMETER
In 51 section NO right boundary ~ SEE THE PARAMETER
In 56 section the boundary of river is out of DTM
In 57 section NO right boundary ~ SEE THE PARAMETER
In 58 section NO left boundary ~ SEE THE PARAMETER
In 59 section NO right boundary ~ SEE THE PARAMETER
In 59 section NO left boundary ~ SEE THE PARAMETER
In 60 section NO right boundary ~ SEE THE PARAMETER
In 60 section NO left boundary ~ SEE THE PARAMETER
In 61 section NO right boundary ~ SEE THE PARAMETER
In 63 section NO right boundary ~ SEE THE PARAMETER
In 64 section NO right boundary ~ SEE THE PARAMETER
In 64 section the boundary of river is out of DTM
In 65 section NO right boundary ~ SEE THE PARAMETER
In 72 section the boundary of river is out of DTM
End of water surface file
Writing the boundary profile
END of Fortran Code ~ OK
DBMI-SQLite driver error:
Error in sqlite3_prepare():
table limiti_alveo has 42 columns but 41 values were
supplied
ERROR: Unable to insert new record: insert into limiti_alveo values ( 2, null, null, null, 318914.156, null, null, null, null, null, null, 4308449.50, null, null, null, null, null, null, 6.71700001, null, null, null, null, null, null, 9.6243830880000001, null, null, null, null, null, null, null, null, null, null, null, null, null, null, 17)
STEP 1
WARNING: Unable to create a new process
Cannot allocate memory: can't create fork
WARNING: Unable to start driver <sqlite>
ERROR: Unable to open database </home/teaiii/grass/data/potomac_utm/teaiii/sqlite/sqlite.db> by driver <sqlite>
Invalid map <quote_punti_adiacenti>
Parse error
Invalid map <inondazione_step1>
Parse error
STEP 2
ERROR: Raster map <inondazione_step1> not found
ERROR: Vector map <inondazione_step1> not found
ERROR: Vector map <inondazione_step2> not found
Invalid map <inondazione_step2>
Parse error
Invalid map <inondazione_step2_isnull>
Parse error
STEP 3
ERROR: Raster map <inondazione_step2> not found
ERROR: Raster map <quote_punti_adiacenti> not found
CODE FORTRAN OF STEP 3
At line 52 of file clean_inundation.f90 (unit = 51, file =
Fortran runtime error: File 'quote_punti_adiacenti' does not
exist
ERROR: Unable to read input from </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/27606.0/inondazione_nuova.txt>
STEP 4
ERROR: Raster map <inondazione_step3> not found
2D MODEL OF DIFFUSION OF FLOODING INONDATION OUTSIDE THE MAIN CHANEL
At line 70 of file 2d_path.f90 (unit = 54, file = '')
Fortran runtime error: File 'inondazione_step3' does not
exist
ERROR: Unable to open ASCII file </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/27606.0/bordi_alveo>
ERROR: Unable to read input from </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/27606.0/reticolo>
ERROR: Raster map <reticolo> not found
ERROR: Raster map <reticolo_thin> not found
WARNING: Raster map <reticolo_thin> not found
WARNING: <reticolo_thin> nothing removed
Invalid map <inondazione_step3>
Parse error
Invalid map <inondazione_step3_isnull>
Parse error
Parse error
Invalid map <diff_inond>
Parse error
ERROR: Raster map <diff_inond> not found
ERROR: Vector map <reticolo> not found
ERROR: Unable to open DXF file </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/27606.0/reticolo.dxf>
ERROR: Vector map <reticolo_interno> not found
ERROR: Vector map <punti3d_reticolo@> not found
FORTRAN CODE OF STEP 4
At line 53 of file correction_from_path.f90 (unit = 51, file
Fortran runtime error: File 'diff_inond' does not exist
ERROR: Unable to read input from </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/27606.0/correzione>
Invalid map <inondazione_step5>
Parse error
Invalid map <inondazione_step5_isnull>
Parse error
Parse error
STEP 5
WARNING: raster <inondazione> not found
ERROR: Raster map <inondazione1> not found
ERROR: Vector map <punti3d_reticolo> not found
ERROR: Vector map <inondazione1> not found
ERROR: Vector map <inondazione> not found
Invalid map <potomac_inund>
Parse error
ERROR: Raster map <potomac_inund> not found
WARNING: Raster map <inondazione_step1> not found
WARNING: <inondazione_step1> nothing removed
WARNING: Raster map <inondazione_step2> not found
WARNING: <inondazione_step2> nothing removed
WARNING: Raster map <inondazione_step2_isnull> not found
WARNING: <inondazione_step2_isnull> nothing removed
WARNING: Raster map <inondazione_step3> not found
WARNING: <inondazione_step3> nothing removed
WARNING: Raster map <reticolo> not found
WARNING: <reticolo> nothing removed
WARNING: Raster map <quote_punti_adiacenti> not found
WARNING: <quote_punti_adiacenti> nothing removed
WARNING: Raster map <inondazione_step3_isnull> not found
WARNING: <inondazione_step3_isnull> nothing removed
WARNING: Raster map <diff_inond> not found
WARNING: <diff_inond> nothing removed
WARNING: Raster map <inondazione_step5> not found
WARNING: <inondazione_step5> nothing removed
WARNING: Raster map <inondazione_step5_isnull> not found
WARNING: <inondazione_step5_isnull> nothing removed
WARNING: Raster map <inondazione1> not found
WARNING: <inondazione1> nothing removed
WARNING: Vector map <inondazione_step1> not found
WARNING: Vector map <inondazione_step2> not found
WARNING: Vector map <reticolo> not found
WARNING: Vector map <diff_inond1> not found
WARNING: <diff_inond1> nothing removed
WARNING: Vector map <reticolo_interno> not found
WARNING: <reticolo_interno> nothing removed
WARNING: Vector map <inondazione1> not found
WARNING: Vector map <overlap> not found
WARNING: <overlap> nothing removed
WARNING: Vector map <inondazione> not found
WARNING: <inondazione> nothing removed
WARNING: Vector map <bordi_alveo> not found
WARNING: <bordi_alveo> nothing removed
WARNING: Table <limiti_alveo> linked to vector map <limiti_alveo> does not exist
(Sat Apr 19 15:01:34 2014) Command finished (4 min 14 sec)
