[GRASS-user] Here is the detailed output I'm getting from r.inund.fluv
Thomas Adams
tea3rd at gmail.com
Sat Apr 19 13:42:29 PDT 2014
Markus,
I don't think I can do this because it would require setting up a
hydrodnamic unsteady flow model for a stream in the NC data set and
preparing the necessary input file for r.inund.fluv once I had successfully
run the model. I can not see in the NC data set that any of this is
available and I am just not in a position to undertake the effort. What is
missing is a georeferenced channel centerline with the associated modeled
water surface elevation profile.
Thank you for your help.
Tom
On Sat, Apr 19, 2014 at 3:42 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Tom,
> On Sat, Apr 19, 2014 at 9:23 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> > All:
> > Below is the detailed output I'm getting from running r.inund.fluv on
> Ubuntu
> > 13.10, GRASS 6.4.3.
> > My DTM is 30m x 30m (the best I can do at the moment) and distances
> between
> > cross-sections is on the order of 300-500 meters -- could this explain my
> > results (no maps are created)?
> Could you please provide an example based on the North Carolina
> dataset? Then it is easier to reproduce.
> Markus
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140419/2d7526cb/attachment-0001.html>
