[GRASS-user] Here is the detailed output I'm getting from r.inund.fluv
Markus Neteler
neteler at osgeo.org
Sat Apr 19 14:13:04 PDT 2014
On Sat, Apr 19, 2014 at 10:42 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> Markus,
> I don't think I can do this because it would require setting up a
> hydrodnamic unsteady flow model for a stream in the NC data set and
> preparing the necessary input file for r.inund.fluv once I had successfully
> run the model. I can not see in the NC data set that any of this is
> available and I am just not in a position to undertake the effort. What is
> missing is a georeferenced channel centerline with the associated modeled
> water surface elevation profile.
Yes, ok. Then I see two options
- shell debugging with -x option, see
http://grasswiki.osgeo.org/wiki/GRASS_Debugging#Shell_script_debugging
- try to contact the authors of r.inund.fluv who will know it better
than most of us.
best
Markus
