[GRASS-user] Here is the detailed output I'm getting from r.inund.fluv
Thomas Adams tea3rd at gmail.com
Sun Apr 20 05:24:03 PDT 2014
Markus,
Thank you for the suggestion; attached is the detail using the -x option.
Cheers!
Tom
On Sat, Apr 19, 2014 at 5:13 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Apr 19, 2014 at 10:42 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> > Markus,
> > I don't think I can do this because it would require setting up a
> > hydrodnamic unsteady flow model for a stream in the NC data set and
> > preparing the necessary input file for r.inund.fluv once I had
> successfully
> > run the model. I can not see in the NC data set that any of this is
> > available and I am just not in a position to undertake the effort. What
> is
> > missing is a georeferenced channel centerline with the associated modeled
> > water surface elevation profile.
> Yes, ok. Then I see two options
> - shell debugging with -x option, see
>   http://grasswiki.osgeo.org/wiki/GRASS_Debugging#Shell_script_debugging
> - try to contact the authors of r.inund.fluv who will know it better
> than most of us.
> best
> Markus
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140420/3570de01/attachment-0001.html>
(Sat Apr 19 23:12:25 2014)
r.inund.fluv --overwrite DTM=chesapeake_final at teaiii W_S_PROFILE=/home/teaiii/Documents/Climate Decision LLC/upper_potomac_up2down.txt RIVER=potomac_river at teaiii FLOODING_MAP=potomac_inund
+ [ -z /usr/local/grass-6.4.3 ]
+ [ --overwrite != @ARGS_PARSED@ ]
+ exec g.parser /usr/local/grass-6.4.3/scripts/r.inund.fluv
+ [ @ARGS_PARSED@ != @ARGS_PARSED@ ]
+ basename /usr/local/grass-6.4.3/scripts/r.inund.fluv
+ PROG=r.inund.fluv
+ [ -z chesapeake_final at teaiii ]
+ g.region save=dtm_res2 --overwrite
+ g.region rast=chesapeake_final at teaiii save=verifica
+ g.region -p
+ g.region region=dtm_res2
+ exec
+ exec
+ read a1 b1
+ read a2 b2
+ read a3 b3
+ read a4 b4
+ read a5 b5
+ read a6 b6
+ read a7 b7
+ read a8 b8
+ read a9 b9
+ exec
+ res=29.99957802
+ [ 29.99957802 -gt 5 ]
/usr/local/grass-6.4.3/scripts/r.inund.fluv: 162: [: Illegal
number: 29.99957802
+ g.message The DTM resolution is 29.99957802 x 29.99957802
meters
The DTM resolution is 29.99957802 x 29.99957802 meters
+ rm .resolution.txt
+ [ -z /home/teaiii/Documents/Climate Decision
LLC/upper_potomac_up2down.txt ]
+ [ -z potomac_river at teaiii ]
+ [ -z potomac_inund ]
+ [ -n  ]
+ res10=10
+ [ -n  ]
+ res20=20
+ [ -n  ]
+ quote100=/home/teaiii/Documents/Climate Decision
+ [ -n  ]
+ echo 29.99957802 * 1.5
+ bc
+ deltax=44.99936703
+ [ -n  ]
+ deltay=0.5
+ g.remove rast=MASK --quiet
WARNING: Raster map <MASK> not found
WARNING: <MASK> nothing removed
+ g.tempfile pid=5365
+ TMPDIR=/home/teaiii/grass/data/potomac_utm/teaiii/.tmp
/teaiii-Wild-Dog-Performance/5365.0
+ [ 0 -ne 0 ]
+ [ -z /home/teaiii/grass/data/potomac_utm/teaiii/.tmp
/teaiii-Wild-Dog-Performance/5365.0 ]
+ rm -r -f /home/teaiii/grass/data/potomac_utm/teaiii/.tmp
+ mkdir /home/teaiii/grass/data/potomac_utm/teaiii/.tmp
+ cp
/usr/local/grass-6.4.3/etc/fortran_code/find_main_channel
/home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-
+ cp
/usr/local/grass-6.4.3/etc/fortran_code/clean_inundation
+ cp /usr/local/grass-6.4.3/etc/fortran_code/2d_path
+ cp
/usr/local/grass-6.4.3/etc/fortran_code/correction_from_path
+ dtm=chesapeake_final at teaiii
+ cp /home/teaiii/Documents/Climate Decision
Dog-Performance/5365.0/profilo
+ v.in.ascii -z input=/home/teaiii/Documents/Climate
Decision LLC/upper_potomac_up2down.txt output=profilo
format=point fs=  skip=0 x=1 y=2 z=3 cat=0 --overwrite
--quiet
+ centerline=potomac_river at teaiii
+ inondazione=potomac_inund
+ g.region nsres=29.99957802 ewres=29.99957802 save=dtm_res2
--overwrite
+ g.region -p
+ r.out.ascii -h input=chesapeake_final at teaiii
output=/home/teaiii/grass/data/potomac_utm/teaiii/.tmp
/teaiii-Wild-Dog-Performance/5365.0/dtm2x2 null=0 --quiet
+ cd
Dog-Performance/5365.0/quote_100
+ cd /home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-
+ echo 29.99957802 44.99936703 0.5
+ echo 'region2.txt' 'dtm2x2' 'limiti_alveo_vect'
'quote_100'
+ g.message Fortran code that automatically find bed river
+ ./find_main_channel
 region2.txt
   4428236.00       4099080.75       414639.531       233037.875       29.9995785           10972        6053
 There are    63283233 no-null cells in Digital Terrain Model
 Read the Digital Terrain Model with Compressed Sparse Row (CSR) algorithm
 Read          73  rows in file of water surface
 In           1 section NO right boundary ~ SEE THE PARAMETER
 In           1 section NO left boundary ~ SEE THE PARAMETER
 In           2 section NO right boundary ~ SEE THE PARAMETER
 In           2 section NO left boundary ~ SEE THE PARAMETER
 In           3 section NO right boundary ~ SEE THE PARAMETER
 In           3 section NO left boundary ~ SEE THE PARAMETER
 In           4 section NO left boundary ~ SEE THE PARAMETER
 In           5 section NO right boundary ~ SEE THE PARAMETER
 In           5 section NO left boundary ~ SEE THE PARAMETER
 In           6 section NO right boundary ~ SEE THE PARAMETER
 In           6 section NO left boundary ~ SEE THE PARAMETER
 In           7 section NO right boundary ~ SEE THE PARAMETER
 In           7 section NO left boundary ~ SEE THE PARAMETER
 In           8 section NO right boundary ~ SEE THE PARAMETER
 In           8 section NO left boundary ~ SEE THE PARAMETER
 In           9 section NO right boundary ~ SEE THE PARAMETER
 In           9 section NO left boundary ~ SEE THE PARAMETER
 In          10 section NO right boundary ~ SEE THE PARAMETER
 In          10 section NO left boundary ~ SEE THE PARAMETER
 In          11 section NO right boundary ~ SEE THE PARAMETER
 In          11 section NO left boundary ~ SEE THE PARAMETER
 In          12 section NO right boundary ~ SEE THE PARAMETER
 In          12 section NO left boundary ~ SEE THE PARAMETER
 In          13 section NO right boundary ~ SEE THE PARAMETER
 In          13 section NO left boundary ~ SEE THE PARAMETER
 In          14 section NO right boundary ~ SEE THE PARAMETER
 In          14 section NO left boundary ~ SEE THE PARAMETER
 In          15 section NO right boundary ~ SEE THE PARAMETER
 In          15 section NO left boundary ~ SEE THE PARAMETER
 In          16 section NO right boundary ~ SEE THE PARAMETER
 In          16 section NO left boundary ~ SEE THE PARAMETER
 In          18 section NO left boundary ~ SEE THE PARAMETER
 In          20 section NO left boundary ~ SEE THE PARAMETER
 In          21 section NO right boundary ~ SEE THE PARAMETER
 In          22 section NO left boundary ~ SEE THE PARAMETER
 In          23 section NO left boundary ~ SEE THE PARAMETER
 In          24 section NO right boundary ~ SEE THE PARAMETER
 In          24 section NO left boundary ~ SEE THE PARAMETER
 In          25 section NO right boundary ~ SEE THE PARAMETER
 In          26 section NO right boundary ~ SEE THE PARAMETER
 In          26 section NO left boundary ~ SEE THE PARAMETER
 In          27 section NO right boundary ~ SEE THE PARAMETER
 In          28 section NO right boundary ~ SEE THE PARAMETER
 In          28 section NO left boundary ~ SEE THE PARAMETER
 In          29 section NO right boundary ~ SEE THE PARAMETER
 In          29 section NO left boundary ~ SEE THE PARAMETER
 In          30 section NO left boundary ~ SEE THE PARAMETER
 In          31 section NO right boundary ~ SEE THE PARAMETER
 In          33 section NO right boundary ~ SEE THE PARAMETER
 In          34 section NO right boundary ~ SEE THE PARAMETER
 In          35 section NO right boundary ~ SEE THE PARAMETER
 In          36 section NO left boundary ~ SEE THE PARAMETER
 In          37 section NO right boundary ~ SEE THE PARAMETER
 In          37 section NO left boundary ~ SEE THE PARAMETER
 In          38 section NO right boundary ~ SEE THE PARAMETER
 In          38 section NO left boundary ~ SEE THE PARAMETER
 In          39 section NO right boundary ~ SEE THE PARAMETER
 In          39 section NO left boundary ~ SEE THE PARAMETER
 In          40 section the boundary of river is out of DTM
 In          40 section NO left boundary ~ SEE THE PARAMETER
 In          41 section NO right boundary ~ SEE THE PARAMETER
 In          41 section NO left boundary ~ SEE THE PARAMETER
 In          43 section NO right boundary ~ SEE THE PARAMETER
 In          43 section NO left boundary ~ SEE THE PARAMETER
 In          44 section NO left boundary ~ SEE THE PARAMETER
 In          46 section the boundary of river is out of DTM
 In          48 section the boundary of river is out of DTM
 In          48 section NO left boundary ~ SEE THE PARAMETER
 In          49 section NO right boundary ~ SEE THE PARAMETER
 In          49 section NO left boundary ~ SEE THE PARAMETER
 In          50 section NO right boundary ~ SEE THE PARAMETER
 In          51 section NO right boundary ~ SEE THE PARAMETER
 In          56 section the boundary of river is out of DTM
 In          57 section NO right boundary ~ SEE THE PARAMETER
 In          58 section NO left boundary ~ SEE THE PARAMETER
 In          59 section NO right boundary ~ SEE THE PARAMETER
 In          59 section NO left boundary ~ SEE THE PARAMETER
 In          60 section NO right boundary ~ SEE THE PARAMETER
 In          60 section NO left boundary ~ SEE THE PARAMETER
 In          61 section NO right boundary ~ SEE THE PARAMETER
 In          63 section NO right boundary ~ SEE THE PARAMETER
 In          64 section NO right boundary ~ SEE THE PARAMETER
 In          64 section the boundary of river is out of DTM
 In          65 section NO right boundary ~ SEE THE PARAMETER
 In          72 section the boundary of river is out of DTM
 End of water surface file
 Writing the boundary profile
 END of Fortran Code ~ OK
+ rm nomefile.txt
+ rm parameter.txt
+ [ -z limiti_alveo_vect ]
+ cd
+ v.in.ascii --o
input=/home/teaiii/grass/data/potomac_utm/teaiii/.tmp
/teaiii-Wild-Dog-Performance/5365.0/limiti_alveo_vect
output=limiti_alveo format=point fs=      skip=0 x=1 y=2
cat=0 --quiet --overwrite
DBMI-SQLite driver error:
Error in sqlite3_prepare():
table limiti_alveo has 42 columns but 41 values were
supplied
ERROR: Unable to insert new record: insert into limiti_alveo values ( 2, null, null, null, 318914.156, null, null, null, null, null, null, 4308449.50, null, null, null, null, null, null, 6.71700001, null, null, null, null, null, null, 9.6243830880000001, null, null, null, null, null, null, null, null, null, null, null, null, null, null, 17)
+ g.region nsres=20 ewres=20 save=dtm_res20 --overwrite
+ g.region -p
/teaiii-Wild-Dog-Performance/5365.0/dtm20x20 null=0 --quiet
+ g.region nsres=10 ewres=10 save=dtm_res10 --overwrite
+ g.region -p
+ g.message STEP 1
STEP 1
+ g.region region=dtm_res10
+ v.surf.idw input=profilo output=quote_punti_adiacenti
npoints=1 layer=1 column=dbl_3 --overwrite --quiet
WARNING: Unable to create a new process
Cannot allocate memory: can't create fork
WARNING: Unable to start driver <sqlite>
ERROR: Unable to open database </home/teaiii/grass/data/potomac_utm/teaiii/sqlite/sqlite.db> by driver <sqlite>
+ r.mapcalc inondazione_step1=if(quote_punti_adiacenti>chesa
peake_final at teaiii)
Invalid map <quote_punti_adiacenti>
Parse error
+ r.mapcalc
inondazione_step1=inondazione_step1/inondazione_step1
Invalid map <inondazione_step1>
Parse error
+ g.message STEP 2
STEP 2
+ r.to.vect -s input=inondazione_step1
output=inondazione_step1 feature=area --overwrite --quiet
ERROR: Raster map <inondazione_step1> not found
+ v.select ainput=inondazione_step1 atype=area alayer=1
binput=potomac_river at teaiii btype=line blayer=1
output=inondazione_step2 operator=overlap --overwrite
--quiet
ERROR: Vector map <inondazione_step1> not found
+ v.to.rast input=inondazione_step2 output=inondazione_step2
use=val layer=1 value=1 rows=4096 --overwrite --quiet
ERROR: Vector map <inondazione_step2> not found
+ r.mapcalc
inondazione_step2_isnull=isnull(inondazione_step2)
Invalid map <inondazione_step2>
Parse error
+ r.mapcalc
inondazione_step2=if(inondazione_step2_isnull,0,1)
Invalid map <inondazione_step2_isnull>
Parse error
+ g.message STEP 3
STEP 3
+ g.region region=dtm_res20
+ r.out.ascii -h input=inondazione_step2
/teaiii-Wild-Dog-Performance/5365.0/inondazione_step2 null=0
--quiet
ERROR: Raster map <inondazione_step2> not found
+ r.out.ascii -h input=quote_punti_adiacenti
/teaiii-Wild-Dog-Performance/5365.0/quote_punti_adiacenti
dp=2 null=0 --quiet
ERROR: Raster map <quote_punti_adiacenti> not found
+ g.message CODE FORTRAN OF STEP 3
+ cd
+ echo 'inondazione_step2' 'profilo' 'inondazione_nuova.txt'
'quote_punti_adiacenti' 'region20.txt' 'region2.txt'
'dtm2x2'
+ ./clean_inundation
At line 52 of file clean_inundation.f90 (unit = 51, file =
Fortran runtime error: File 'quote_punti_adiacenti' does not
exist
+ rm nomefile.txt
+ [ -z inondazione_nuova.txt ]
+ cd
+ r.in.ascii
/teaiii-Wild-Dog-Performance/5365.0/inondazione_nuova.txt
output=inondazione_step3 mult=1.0 or read from header nv=0
--overwrite --quiet
ERROR: Unable to read input from </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/5365.0/inondazione_nuova.txt>
+ g.message STEP 4
STEP 4
+ r.out.ascii -h input=inondazione_step3
/teaiii-Wild-Dog-Performance/5365.0/inondazione_step3 null=0
--quiet
ERROR: Raster map <inondazione_step3> not found
+ g.message 2D MODEL OF DIFFUSION OF FLOODING INONDATION
OUTSIDE THE MAIN CHANEL
2D MODEL OF DIFFUSION OF FLOODING INONDATION OUTSIDE THE MAIN CHANEL
+ cd
+ echo 'profilo' 'inondazione_step3' 'reticolo'
'region20.txt' 'dtm20x20' 'limiti_alveo_vect' 'region2.txt'
'dtm2x2' 'bordi_alveo'
+ ./2d_path
At line 70 of file 2d_path.f90 (unit = 54, file = '')
Fortran runtime error: File 'inondazione_step3' does not
exist
+ rm nomefile.txt
+ [ -z reticolo ]
+ cd
+ v.in.ascii -n
/teaiii-Wild-Dog-Performance/5365.0/bordi_alveo
output=bordi_alveo format=standard fs=  skip=0 x=1 y=2 z=0
cat=0 --overwrite --quiet
ERROR: Unable to open ASCII file </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/5365.0/bordi_alveo>
+ r.in.ascii
/teaiii-Wild-Dog-Performance/5365.0/reticolo output=reticolo
mult=1.0 or read from header nv=* --overwrite --quiet
ERROR: Unable to read input from </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/5365.0/reticolo>
+ r.thin input=reticolo output=reticolo_thin iterations=200
--overwrite --quiet
ERROR: Raster map <reticolo> not found
+ r.to.vect input=reticolo_thin output=reticolo feature=line
--overwrite --quiet
ERROR: Raster map <reticolo_thin> not found
+ g.remove rast=reticolo_thin --quiet
WARNING: Raster map <reticolo_thin> not found
WARNING: <reticolo_thin> nothing removed
+ r.mapcalc
inondazione_step3_isnull=isnull(inondazione_step3)
Invalid map <inondazione_step3>
Parse error
+ r.mapcalc
inondazione_step3=if(inondazione_step3_isnull,0,1)
Invalid map <inondazione_step3_isnull>
Parse error
+ r.mapcalc diff_inond=inondazione_step2-inondazione_step3
Parse error
+ r.mapcalc diff_inond=if(diff_inond,1,0,0)
Invalid map <diff_inond>
Parse error
+ r.null map=diff_inond setnull=0 --overwrite --quiet
ERROR: Raster map <diff_inond> not found
+ r.to.vect input=diff_inond output=diff_inond1 feature=area
--overwrite --quiet
+ v.out.dxf input=reticolo
/teaiii-Wild-Dog-Performance/5365.0/reticolo.dxf --quiet
ERROR: Vector map <reticolo> not found
+ v.in.dxf -1
output=reticolo --overwrite --quiet
ERROR: Unable to open DXF file </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/5365.0/reticolo.dxf>
+ v.select ainput=reticolo atype=line alayer=1
binput=diff_inond1 btype=area blayer=1
output=reticolo_interno operator=overlap --overwrite --quiet
+ v.to.points input=reticolo_interno
type=point,line,boundary,centroid
output=punti_reticolo_interno llayer=1 dmax=30 --overwrite
--quiet
ERROR: Vector map <reticolo_interno> not found
+ g.region region=dtm_res20 --quiet
+ v.drape input=punti_reticolo_interno
type=point,centroid,line,boundary,face,kernel rast=reticolo
method=nearest output=punti3d_reticolo --overwrite --quiet
+ v.out.ascii input=punti3d_reticolo
/teaiii-Wild-Dog-Performance/5365.0/punti3d_reticolo
format=point fs=  dp=2 --quiet
ERROR: Vector map <punti3d_reticolo@> not found
+ r.out.ascii -h input=diff_inond
/teaiii-Wild-Dog-Performance/5365.0/diff_inond null=0
--quiet
+ g.message FORTRAN CODE OF STEP 4
+ cd
+ echo 'diff_inond' 'punti3d_reticolo' 'correzione'
'region10.txt' 'dtm2x2' 'region2.txt'
+ ./correction_from_path
At line 53 of file correction_from_path.f90 (unit = 51, file
Fortran runtime error: File 'diff_inond' does not exist
+ rm nomefile.txt
+ [ -z correzione ]
+ cd
+ r.in.ascii
/teaiii-Wild-Dog-Performance/5365.0/correzione
output=inondazione_step5 mult=1.0 or read from header nv=0
--overwrite --quiet
ERROR: Unable to read input from </home/teaiii/grass/data/potomac_utm/teaiii/.tmp/teaiii-Wild-Dog-Performance/5365.0/correzione>
+ r.mapcalc
inondazione_step5_isnull=isnull(inondazione_step5)
Invalid map <inondazione_step5>
Parse error
+ r.mapcalc
inondazione_step5=if(inondazione_step5_isnull,0,1)
Invalid map <inondazione_step5_isnull>
Parse error
+ r.mapcalc inondazione=inondazione_step5+inondazione_step3
Parse error
+ g.message STEP 5
STEP 5
+ g.rename rast=inondazione,inondazione1 --overwrite --quiet
WARNING: raster <inondazione> not found
+ r.null map=inondazione1 setnull=0 --quiet
ERROR: Raster map <inondazione1> not found
+ r.to.vect -s input=inondazione1 output=inondazione1
+ v.patch input=potomac_river at teaiii,punti3d_reticolo
output=overlap --overwrite --quiet
ERROR: Vector map <punti3d_reticolo> not found
+ v.select ainput=inondazione1 atype=area alayer=1
binput=overlap btype=line blayer=1 output=inondazione
ERROR: Vector map <inondazione1> not found
+ v.to.rast input=inondazione output=potomac_inund use=val
ERROR: Vector map <inondazione> not found
+ [ -n  ]
+ r.mapcalc
potomac_inund=if(potomac_inund==1,if((potomac_inund
*quote_punti_adiacenti-
chesapeake_final at teaiii)>0,(potomac_inund
*quote_punti_adiacenti-chesapeake_final at teaiii),null()))
Invalid map <potomac_inund>
Parse error
+ rm -f .colore_inondazione.file
+ echo 10 blue
+ echo 0 aqua
+ echo nv white
+ echo end
+ cat .colore_inondazione.file
+ r.colors map=potomac_inund color=rules --quiet
ERROR: Raster map <potomac_inund> not found
+ rm .colore_inondazione.file
+ g.remove rast=inondazione_step1,inondazione_step2,inondazi
one_step2_isnull,inondazione_step3,reticolo,quote_punti_adia
centi --quiet
WARNING: Raster map <inondazione_step1> not found
WARNING: <inondazione_step1> nothing removed
WARNING: Raster map <inondazione_step2> not found
WARNING: <inondazione_step2> nothing removed
WARNING: Raster map <inondazione_step2_isnull> not found
WARNING: <inondazione_step2_isnull> nothing removed
WARNING: Raster map <inondazione_step3> not found
WARNING: <inondazione_step3> nothing removed
WARNING: Raster map <reticolo> not found
WARNING: <reticolo> nothing removed
WARNING: Raster map <quote_punti_adiacenti> not found
WARNING: <quote_punti_adiacenti> nothing removed
+ g.remove rast=inondazione_step3_isnull,diff_inond,inondazi
one_step5,inondazione_step5_isnull,inondazione1 --quiet
WARNING: Raster map <inondazione_step3_isnull> not found
WARNING: <inondazione_step3_isnull> nothing removed
WARNING: Raster map <diff_inond> not found
WARNING: <diff_inond> nothing removed
WARNING: Raster map <inondazione_step5> not found
WARNING: <inondazione_step5> nothing removed
WARNING: Raster map <inondazione_step5_isnull> not found
WARNING: <inondazione_step5_isnull> nothing removed
WARNING: Raster map <inondazione1> not found
WARNING: <inondazione1> nothing removed
+ g.remove vect=inondazione_step1,inondazione_step2,reticolo
--quiet
WARNING: Vector map <inondazione_step1> not found
WARNING: Vector map <inondazione_step2> not found
WARNING: Vector map <reticolo> not found
+ g.remove
vect=diff_inond1,reticolo_interno,inondazione1,overlap
--quiet
WARNING: Vector map <diff_inond1> not found
WARNING: <diff_inond1> nothing removed
WARNING: Vector map <reticolo_interno> not found
WARNING: <reticolo_interno> nothing removed
WARNING: Vector map <inondazione1> not found
WARNING: Vector map <overlap> not found
WARNING: <overlap> nothing removed
+ [ potomac_inund = inondazione ]
+ g.remove vect=inondazione --quiet
WARNING: Vector map <inondazione> not found
WARNING: <inondazione> nothing removed
+ [ -n  ]
+ g.remove vect=profilo --quiet
+ [ -n  ]
+ g.remove vect=bordi_alveo,limiti_alveo --quiet
WARNING: Vector map <bordi_alveo> not found
WARNING: <bordi_alveo> nothing removed
WARNING: Table <limiti_alveo> linked to vector map <limiti_alveo> does not exist
+ rm -r /home/teaiii/grass/data/potomac_utm/teaiii/.tmp
+ exit 0
(Sat Apr 19 23:15:58 2014) Command finished (3 min 33 sec)
