[GRASS-user] r.horizon distance units
Nikos Alexandris
nik at nikosalexandris.net
Mon Aug 11 22:48:54 PDT 2014
On 11.08.2014 22:10, Tyler Smith wrote:
> Hello,
Hi Tyler,
> I'm having some trouble with r.horizon. I've got a very big DEM, and
> I
> keep running out of memory. After some experiments, I think the
> options
> bufferzone and maxdistance may be part of the problem. It isn't
> listed
> in the help file what the units for these are.
> I'm preparing maps for use in r.sun, and the example in the r.horizon
> help page suggests I use bufferzone=200 and maxdistance=2000. Does
> this
> mean meters? units from the map projection (which are degrees)?
> Omitting
> these parameters I can complete an analysis in a minute or so, when
> including them produces a crash sometime after the process consumes
> all
> my RAM and swap memory.
In all 6.x series as well as in GRASS ver. 7.0, the manual for
r.horizon notes:
At the moment the elevation and maximum distance must be measured in
meters, even if you use geographical coordinates (longitude/latitude).
If your projection is based on distance (easting and northing), these
too must be in meters. The buffer parameters must be in the same units
as the raster coordinates.
Hope this helps further,
Nikos
