[GRASS-user] problem in getting r.in.gdal to work
César Augusto Ramírez Franco
caesarivs at gmail.com
Wed Aug 13 11:52:50 PDT 2014
What does the output of gdalinfo
/home/umberto/Documenti/unimi/ppg/summer_at_home/debris/Debris_Mask.tif
say? Is it a valid GeoTIFF file?
2014-08-13 13:04 GMT-05:00 Umberto Filippo Minora <umbertofilippo at tiscali.it
> Il 13/08/2014 19:11, Umberto Filippo Minora ha scritto:
> I am having problem in importing tif rasters in GRASS.
> When I try a command like
> r.in.gdal input= raster1 output= raster2
> being "raster1" my .tif file (I can open it in qgis), the console outputs
> this message
> ERROR 4: `/home/umberto/Documenti/unimi/ppg/summer_at_home/d
> ebris/Debris_Mask.tif' not recognised as a supported file
> format.
> What would be the problem in my case?
> I am a very beginner user of GRASS, hope someone could help me.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> Sorry, I have to correct my thread.
> Raster don't open neither in qgis.
> I think there should be problems in the GDAL dependencies, since I tried
> to remove and re-install GRASS, qgis, and GDAL for another problem (thus
> creating this new one in the thread).
> Would it be a solution to remove everything again and re-install again?
> Moreover, I performed a GDAL installation in the 2013 using this script
> <https://gist.github.com/lossyrob/4348503>, and I am used to remove my
> packages using these command lines from terminal:
> sudo apt-get remove --purge package
> sudo apt-get autoremove
> sudo aptutude remove packagename
> Would it be possible that having run that script would consist in some
> sort of file still remaining un-removed which could create any conflicts?
> Any help would be really appreciated.
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias
Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140813/6d374a66/attachment-0001.html>
