[GRASS-user] Question about Elevation Maps and Shaded Relief Maps
Ben Winnick benwinnick at gmail.com
Thu Aug 21 16:06:43 PDT 2014
I have created an elevation map and a shaded relief map for the same area.
 I know there is a way that they can both be viewed simultaneously so that
you can see the elevations (as indicated by color) and the shaded relief at
the same time.  Currently I am only able to view one at a time depending on
which map is on top of the other.  How can I change that so that I can see
both maps at the same time?
Thanks,
Ben
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140821/e0f4cbe0/attachment.html>
