[GRASS-user] GRASS 7.0.0
rengifo
rengifoo at yahoo.de
Fri Aug 22 14:09:58 PDT 2014
Hi Hamish,
Thanks a lot for taking the time to look trough my problem with the
grass70 installation. Your script did the trick. I have grass70 up and
running, together with grass 64.
Thanks a lot
best regards.
Rengifo
On fr., 2014-08-22 at 08:47 +1200, Hamish wrote:
> Rengifo wrote:
> > recently I installed GRASS 7.0.0 on ubuntu 14.04 (32 bits). When I
> > tried to open by typing grass70 command I get the following error
> > message: python: can't open file
> > '/usr/lib/grass70/gui/wxpython/gis_set.py': [Errno 2] No such file or
> > directory Received EXIT message from GUI. GRASS is not started.
> Hi,
> since you are using Ubuntu 14.04 I might recommend this script to
> install the GRASS 7.0nightly package and sample dataset:
> https://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/bin/install_grass7.sh
> Some minor adjustments would be needed, but if you follow it line
> by line, set your account name, and ignore the "Desktop GIS" directory
> stuff I think it will be ok. It puts the data in /usr/local/share/grass,
> you may wish to just put it in your home directory.
> It sets things up so that you can run in parallel with GRASS 6.4
> packages, i.e. have both versions installed at the same time. (GRASS
> 6.4.4 is now available for 14.04 in the UbuntuGIS ppa)
> One thing currently broken in there is the wxGUI's parsing of g.version
> output, so the splash screen comes back as "Version ?", but that's just
> cosmetic.
> regards,
> Hamish
