[GRASS-user] problem to install grass70 on ubuntu 12.04
César Augusto Ramírez Franco
caesarivs at gmail.com
Wed Aug 27 13:25:59 PDT 2014
What does the following query return?
$ apt-cache policy libgdal1h libgeos-c1 libproj0
libgdal1h:
Instalados: 1.11.0+dfsg-1~exp2~trusty2
Candidato: 1.11.0+dfsg-1~exp2~trusty2
Tabla de versión:
*** 1.11.0+dfsg-1~exp2~trusty2 0
500 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/
trusty/main amd64 Packages
100 /var/lib/dpkg/status
1.10.1+dfsg-5ubuntu1 0
500 http://co.archive.ubuntu.com/ubuntu/ trusty/universe amd64
Packages
libgeos-c1:
Instalados: 3.4.2-4ubuntu1
Candidato: 3.4.2-4ubuntu1
Tabla de versión:
*** 3.4.2-4ubuntu1 0
Packages
libproj0:
Instalados: 4.8.0-2ubuntu2
Candidato: 4.8.0-2ubuntu2
Tabla de versión:
*** 4.8.0-2ubuntu2 0
Packages
Maybe those packages versions are older on official 12.04 repos or maybe
they aren't available at all... I would recommend upgrading to current LTS
Trusty 14.04, or trying to add the ubuntugis-unstable PPA:
https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable
It might have the appropiate packages for it to install correctly
2014-08-27 15:10 GMT-05:00 Markus Neteler <neteler at osgeo.org>:
> On Wed, Aug 27, 2014 at 9:08 PM, César Augusto Ramírez Franco
> <caesarivs at gmail.com> wrote:
> > I don't know why, but there appears to be a conflict between grass70 and
> > grass70-core packages.
> > I've been using that PPA on 14.04 but the package grass70 is not
> installed
> > in my system:
> > And grass is working OK, so I'd say the workaround should be issuing:
> > sudo apt-get install grass70-core grass70-gui
> pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70-core grass70-gui
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
> grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
> Depends: libgeos-c1 (>= 3.4.2) but it is not going to
> be installed
> Depends: libproj0 (>= 4.8.0-1) but it is not going to
> be installed
> Recommends: gdal-bin but it is not going to be installed
> Recommends: proj-bin but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> ... also failing today (Ubuntu 12.04 here)
> Markus
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias
Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140827/77d05617/attachment-0001.html>
