[GRASS-user] grass 7 : ERROR: G_malloc
Markus Neteler
neteler at osgeo.org
Wed Dec 10 11:06:13 PST 2014
On Wed, Dec 10, 2014 at 6:44 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 10/12/14 13:33, image93 wrote:
>> Hello,
>> I tried several tests with grass 7 on my windows station.
>> When i launch the process (v.isochrones), error messages appear, one of
>> them
>> is ERROR: G_malloc.
>> Please find below the message.
>> ERROR: G_malloc: impossible d'allouer 24576 octets de mémoire à
>> setup.c:124
The message indicated that it is not the very latest GRASS GIS 7
version because it would indicate the full path to the failing file,
something like
ERROR: G_malloc: unable to allocate xxx bytes of memory at path/to/file:zz
>> ERROR: Sorry, <type> is not a valid parameter
>> ERROR: Sorry, <name> is not a valid parameter
> Option names were recently changed for g.remove. Which version of grass7
> (which svn revision) do you have ?
> Try installing a more recent build.
Seems that this will be the solution.
Markus
