[GRASS-user] Another GRASS GIS 7.0 visualization: hydrologic model simulation animation
Thomas Adams
tea3rd at gmail.com
Thu Dec 11 06:13:49 PST 2014
Jose,
The scripts are attached; please understand that I have to slightly modify
the scripts each time I run them for a new location; this is something I
need to improve.
Best,
Tom
On Thu, Dec 11, 2014 at 6:47 AM, Moyano Capilla, Jose Eduardo <
josmoy at ceh.ac.uk> wrote:
> Thank you very much!
> If you don’t mind I would really appreciate to have those scripts to have
> a look to them. I think I still have a lot to learn J
> Cheers,
> Jose
> *From:* Thomas Adams [mailto:tea3rd at gmail.com]
> *Sent:* 11 December 2014 13:31
> *To:* Moyano Capilla, Jose Eduardo; grass-user at lists.osgeo.org
> *Subject:* Re: [GRASS-user] Another GRASS GIS 7.0 visualization:
> Jose,
> The approach I took was very different. First of all:
> (1) I'm using (Ubuntu) Linux -- this makes the GRASS scripting easier, for
> me
> (2) I used GRASS ps.map to generate postscript files, and then ps2pdf,
> which I convert to png images using ImageMagick convert
> (3) since this was all scripted, it runs automatically -- consists of two
> scripts; #1 controls the looping, #2 does all the GRASS GIS work and is
> called by #1
> (4) the final (manual step, but I could have had it included in my script)
> was to follow the procedures found here
> http://grasswiki.osgeo.org/wiki/Movies (thanks to Markus Neteler) to
> generate the movie from all the individual images
> I'd be happy to provide my scripts if you care to see them.
> Best,
> Tom
> On Thu, Dec 11, 2014 at 2:55 AM, Moyano Capilla, Jose Eduardo <
> Hi Thomas,
> Thank you for your video! I write to you because I was trying to create
> something similar with the animation tool in GRASS 7.0 but I was unable. If
> I tried in Windows I get an error message and the program crashes down. If
> I try in Linux the program says that I need a codec, that I downloaded and
> installed but I shouldn’t do it properly because it’s still not working.
> How did you manage to do it? Did you had any problem?
> Anyway, I gave up and I am working now with ArcGIS, where I get a result
> good enough for my purposes, but I would like to know if there is any trick
> or something, as I don’t what I was doing wrong.
> Thanks in advance!
> Jose
> *Sent:* 10 December 2014 22:16
> *To:* grass-user at lists.osgeo.org
> *Subject:* [GRASS-user] Another GRASS GIS 7.0 visualization: hydrologic
> All:
> I thought some might be interested in seeing another hydrologic model
> simulation animation using GRASS GIS 7.0: http://vimeo.com/113855426 — Potomac
> River basin, RDHM simulation, 06/15/2006 - 07/11/2006 near Washington, DC.
> In the near future, I'd like to create a 4-panel animation and include
> soil moisture and snow water equivalent and some higher resolution urban
> flooding movies as well.
> Cheers!
> Tom
> This message (and any attachments) is for the recipient only. NERC is
> subject to the Freedom of Information Act 2000 and the contents of this
> email and any reply you make may be disclosed by NERC unless it is exempt
> from release under the Act. Any material supplied to NERC may be stored in
> an electronic records management system.
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141211/f6dcb114/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141211/f6dcb114/attachment-0002.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141211/f6dcb114/attachment-0003.obj>
