[GRASS-user] Problem with r.basin in grass7
    Helmut Kudrnovsky
    hellik at web.de
    Mon Dec 15 13:42:34 PST 2014
> I run the r.basin command and it finished !!!!
great!
>I do get 2 blocks of warnings ... Are they important ?
>Here they are:
>Reading raster map <t_elev_ned_30m_strahler>...
>Reading raster map <t_elev_ned_30m_drainage_e>...
>Reading raster map <r_elevation_crop>...
>WARNING: Width for column x set to 255 (was not specified by OGR), some
strings may be truncated!
>WARNING: Width for column y set to 255 (was not specified by OGR), some
these warnings come from the underlying involved ogr/gdal library and can't
be suppressed. these can be ignored.
>WARNING: 'windows/original' was found in more mapsets (also found in
<PERMANENT>)
>WARNING: Using <original at landsat>
the original region is stored in the beginning of a r.basin run and restored
in the finish of the r.basin run. your multiple "original" seems to be a
left over of earlier r.basin runs (?). you can remove these by g.remove
type=region ....
by r63549
(http://lists.osgeo.org/pipermail/grass-commit/2014-December/034459.html)
I've added it to the r.basin script to do it autmatically.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5177945.html
Sent from the Grass - Users mailing list archive at Nabble.com.
