[GRASS-user] Problem with r.basin in grass7
Andrea Timmermann
timmermann at gmx.at
Tue Dec 16 12:19:38 PST 2014
Hi, thanks for the answers!!
I still have a problem, since my DEMs have a very high resolution. I tried to run r.basin using a lower resolution of the DEMs, but I do get an error.
I am using the NC database. First I run r.basin with the DEM at the original resolution. Then I adjusted the resolution of g.region, resampled my DEM, re-adjusted the g.region settings and finally re-run r.basin. Here are all my steps.
A) Run r.basin using the original DEM
A1) Set the region and checked r.info for the DEM
g.region -a raster=elev_ned_30m at PERMANENT align=elev_ned_30m at PERMANENT
g.region -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 30
ewres: 30
rows: 450
cols: 500
cells: 225000
r.info map=elev_ned_30m at PERMANENT
| Map: elev_ned_30m at PERMANENT Date: Tue Nov 7 00:35:18 2006 |
| Mapset: PERMANENT Login of Creator: helena |
| DataBase: C:\Users\Andrea\Documents\grassdata |
| Title: South-West Wake county: National Elevation Data 30m ( elev_ned30 |
| Timestamp: none |
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
| Rows: 450 |
| Columns: 500 |
| Total Cells: 225000 |
| Projection: Lambert Conformal Conic |
| N: 228500 S: 215000 Res: 30 |
| E: 645000 W: 630000 Res: 30 |
| Range of data: min = 55.1736 max = 156.3865 |
| Data Description: |
| generated by r.proj |
| Comments: |
| r.proj input="ned1arcsec" location="northcarolina_latlong" mapset="h\ |
| elena" output="elev_ned30m" method="cubic" resolution=30 |
A2) Run r.basin
r.basin --verbose --overwrite map=elev_ned_30m at PERMANENT prefix=a dir=C:\Users\Andrea\t20 threshold=40 coordinates=636654.791181,218824.126649
I got the "DROP TABLE" error again, but since it is at the end and it still gives all the results I think I will just ignore it
Reading raster map <a_elev_35_strahler>...
Reading raster map <a_elev_35_drainage_e>...
Reading raster map <r_elevation_crop>...
ERROR: Error while executing: 'DROP TABLE summary'
B) Run r.basin using a lower resolution DEM
B1) I changed the resolution of the computational region
g.region res=35
g.region -p
zone: 0
datum: nad83
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 34.97409326
ewres: 34.96503497
rows: 386
cols: 429
cells: 165594
B2) Resampled my DEM and readjusted the computational region
r.resample --overwrite --verbose input=elev_ned_30m at PERMANENT output=elev_35
g.region -a --overwrite raster=elev_35 at user1 align=elev_35 at user1
g.region -p
zone: 0
datum: nad83
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 34.97409326
ewres: 34.96503497
rows: 386
cols: 429
cells: 165594
r.info map=elev_35
| Map: elev_35 Date: Tue Nov 7 00:35:18 2006 |
| Mapset: user1 Login of Creator: helena |
| Timestamp: none |
| Type of Map: raster Number of Categories: 0 |
| Data Type: FCELL |
| Rows: 386 |
| Columns: 429 |
| Total Cells: 165594 |
| N: 228500 S: 215000 Res: 34.97409326 |
| E: 645000 W: 630000 Res: 34.96503497 |
| Range of data: min = 55.77085 max = 156.3865 |
| Data Description: |
| Comments: |
B3) Run r.basin
r.basin --verbose --overwrite map=elev_35 prefix=a coordinates=636654.791181,218824.126649 dir=C:\Users\Andrea\F threshold=40
Get this error:
Updating attributes...
r.to.vect complete.
All in RAM calculation...
ERROR: Region resolution and raster map <a_elev_35_strahler> resolution differs. Run 'g.region rast=a_elev_35_strahler' to set proper region resolution.
Checked a_elev_35_strahler, which is the same as in g.region -p
r.info map=a_elev_35_strahler
| Map: a_elev_35_strahler Date: Tue Dec 16 20:13:24 2014 |
| Mapset: user1 Login of Creator: Andrea |
| Title: ( a_elev_35_strahler ) |
| Timestamp: none |
| Data Type: CELL |
| Rows: 386 |
| Columns: 429 |
| Range of data: min = 1 max = 3 |
| Data Description: |
| generated by r.stream.order |
| Comments: |
| r.stream.order stream_rast="a_elev_35_stream_e" direction="a_elev_35\ |
| _drainage_e" strahler="a_elev_35_strahler" horton="a_elev_35_horton"\ |
| shreve="a_elev_35_shreve" hack="a_elev_35_hack" memory=300 |
Tried anyways what the error message suggested:
g.region -p
zone: 0
datum: nad83
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 34.97409326
ewres: 34.96503497
rows: 386
cols: 429
cells: 165594
And rerun r.basin:
Thanks!
Gesendet: Montag, 15. Dezember 2014 um 22:42 Uhr
Von: "Helmut Kudrnovsky" <hellik at web.de>
An: grass-user at lists.osgeo.org
Betreff: Re: [GRASS-user] Problem with r.basin in grass7
> I run the r.basin command and it finished !!!!
great!
>I do get 2 blocks of warnings ... Are they important ?
>Here they are:
>Reading raster map <t_elev_ned_30m_strahler>...
>Reading raster map <t_elev_ned_30m_drainage_e>...
>WARNING: Width for column x set to 255 (was not specified by OGR), some
strings may be truncated!
>WARNING: Width for column y set to 255 (was not specified by OGR), some
these warnings come from the underlying involved ogr/gdal library and can't
be suppressed. these can be ignored.
>WARNING: 'windows/original' was found in more mapsets (also found in
<PERMANENT>)
>WARNING: Using <original at landsat>
the original region is stored in the beginning of a r.basin run and restored
in the finish of the r.basin run. your multiple "original" seems to be a
left over of earlier r.basin runs (?). you can remove these by g.remove
type=region ....
by r63549
(http://lists.osgeo.org/pipermail/grass-commit/2014-December/034459.html)
I've added it to the r.basin script to do it autmatically.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5177945.html[http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5177945.html]
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user[http://lists.osgeo.org/mailman/listinfo/grass-user]
