[GRASS-user] Error with r.stream.basins in GRASS7
Markus Neteler
neteler at osgeo.org
Sat Feb 1 02:53:50 PST 2014
On Sat, Feb 1, 2014 at 9:24 AM, Micha Silver <micha at arava.co.il> wrote:
> On 01/08/2014 06:39 PM, Johannes Radinger wrote:
> Hi,
> I just tried to launch the r.stream.basins add-on in G7,
> however instead of seeing the GUI for the add-on I run into following error:
> Unable to fetch interface description for command 'r.stream.basins'.
> Details:
> GRASS_INFO_ERROR(31075,1): Incompatible library version for module. You need
> to rebuild GRASS or untangle multiple installations.
> GRASS_INFO_END(31075,1)
> I've seen this also.
You'll have to find the outdated addon binary...
AFAIK this happens when a libgis change was done.
Markus
