[GRASS-user] grass 6.4.3 and db.connect
Markus Neteler neteler at osgeo.org
Sat Feb 1 03:07:07 PST 2014
Paul,
On Fri, Jan 31, 2014 at 10:43 PM, Paul Shapley <p.shapley at gmail.com> wrote:
> Hi,
> I am using 'db.connect' to get access to a sqlite database. I have renamed
> the database extension from '.sqlite' to '.db' and placed it in the
> 'PERMANENT' directory but not entirely sure if i've correctly set this
> sqlite access up correctly.
Did you do the connection setting as outlined in the manual?
http://grass.osgeo.org/grass64/manuals/db.connect.html
--> SQLite
What do you get with
db.connect -p
Markus
