[GRASS-user] [GRASS-dev] Object-based image classification in GRASS
Rainer M Krug
Rainer at krugs.de
Thu Feb 13 01:20:47 PST 2014
On 02/13/14, 09:58 , Blumentrath, Stefan wrote:
> Personally, I do not have any problems with the names of r.stats,
> r.univar or r.statistics.
> However, I see that r.statistics2 or r.statistics3 is not a too elegant
> solution…
> If you really plan to rename all these modules, what about a
> two-dot-name like r.statistics.*
I think that the two-dot-name solution would be the way to go. This
would add more structure to the naming, and would make it easier to find
all modules doing stats.
> Yet, there are more modules for
> calculating different statistics (like e.g. r.quantile)... So personally
Over time, the existing other modules could be renamed, but the original
modules could stay and just give a warning: "deprecated - use
r.statistics.whatever instead" and execute the correct module.
And then in the next major version, these could raise an error and not
execute the module, and finally just delete the original module.
Cheers,
Rainer
> I would just rename r.statistics2 and r.statistics3 and leave the rest
> as it is…
> Naming the modules exactly to what they do will not be too easy I guess
> as they have different options which make them really versatile tools.
> r.univar for example has an option to overlay with a cell map for zoning
> “zonal statistics” (at least in GRASS 7)… The main difference to
> r.statistics is in this case that it does not produce map-output…
> r.stats (which is one of my favorites btw.) can do much more than just
> summarizing maps, the main characteristic of r.stats is (as I see it)
> that it tabulates one or more rasters…
> Just my 2c.
> Cheers
> Stefan
> *From:*grass-user-bounces at lists.osgeo.org
> [mailto:grass-user-bounces at lists.osgeo.org] *On Behalf Of *Michael Barton
> *Sent:* 13. februar 2014 00:22
> *To:* grass-user grass-user
> *Subject:* Re: [GRASS-user] [GRASS-dev] Object-based image
> The names aren't too far off, but I admit that they are not completely
> obvious.
> To think about potential replacement names it is good to think what they do.
> r.univar calculates aggregate statistics for values across all cells of
> a map
> r.stats (which to me has the most confusing name) will provide cell
> counts or areas for each value for all cells in a map
> r.statistics calculates aggregate statistics of values in a map that are
> overlain by clusters of cells in another map
> Some ideas
> r.univar -> r.mapstats
> r.statistics -> r.coverstats
> r.stats -> r.mapsummary
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:
> 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Feb 12, 2014, at 1:00 PM, <grass-user-request at lists.osgeo.org
> <mailto:grass-user-request at lists.osgeo.org>>
> <mailto:grass-user-request at lists.osgeo.org>> wrote:
> *From: *Vaclav Petras <wenzeslaus at gmail.com <mailto:wenzeslaus at gmail.com>>
> *Subject: **Re: [GRASS-user] [GRASS-dev] Object-based image
> classification in GRASS*
> *Date: *February 12, 2014 at 9:28:29 AM MST
> *To: *Martin Landa <landa.martin at gmail.com <mailto:landa.martin at gmail.com>>
> *Cc: *GRASS user list <grass-user at lists.osgeo.org
> <mailto:grass-user at lists.osgeo.org>>, GRASS developers list
> <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>>
> On Wed, Feb 12, 2014 at 7:42 AM, Martin Landa <landa.martin at gmail.com
> <mailto:landa.martin at gmail.com>>wrote:
> Hi,
> 2014-02-12 13:41 GMT+01:00 Nikos Alexandris <nik at nikosalexandris.net
> <mailto:nik at nikosalexandris.net>>:
>> think of simply using "r.statistics2" and providing an input "cover=" map
> btw, it remembers me that we haven't yet decided about renaming
> `r.statistics2` and `r.statistics3` to any reasonable name...
> And they confuses with r.stats and r.univar. And r.univar is the most
> basic one from these, I would say, and has the most cryptic name.
> Is the merging (some of) them together still an option?
> Vaclav
> Martin
> Martin Landa <landa.martin gmail.com <http://gmail.com/>>
> * http://geo.fsv.cvut.cz/gwiki/Landa
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
